Part Number: SYSCONFIG
Other Parts Discussed in Thread: MSPM0G1105
Please tell me how to display the names I set on pins after pin assignment has been completed.
Hiroshi Yamada
Hiroshi Yamada
Sorry.
Could you please give me some advice regarding this inquiry?
I would like to know how to display on the assigned pins like the STM32cubeMX I was using.
Hiroshi Yamada
Hiroshi,
Unlike STM32CubeMX we don't show the labels beside the pins. I do think we should do this for non-BGA packages in the future.
A couple of things that may help are.
1) we do indicate which pins are associated with your current selection. Below Pins 19 and 20 are used by my current selection in SysConfig.
2) If you put your mouse over a pin it will show additional information including the label as long as it is not the current selection. Here I have my mouse over pin 6 and it shows me the label I assigned "WILLOW".
John
Hi John,
Thank you for your comment.
I understand.
I have already checked two of your suggestions.
I would definitely like labels.
I have one more question.
Apart from the advice in 2), is there a way to display a list of which pins are assigned to which functions?
Hiroshi Yamada
Hiroshi,
Which device are you using? If you are doing software configuration some devices generate a header file that has much of this information but not as concise as what you would ideally want to see.
John
Hi John
Sorry for the late reply.
The device I'm using is MSPM0G1105.
Hiroshi Yamada
Thank you Hiroshi.
For MSPM0 devices there is a ti_msp_dl_config.h file generated that has the information. However it is pretty detailed and not a summary.
John
