Part Number: C2000WARE-MOTORCONTROL-SDK
Running InstaSPIN Projects and Labs User’s Guide InstaSPIN-FOC for F28004xC, laboration 1.
Is there some way to avoid this continuous occuring error messag.should not be like this all the time.. ?
May I know which board are you using? Your own board or TI EVM kit? And is the power supply enough and stable if you try to run the motor under load?
And please don't set any breakpoint in ISR code if you enable the real-time silicon debug.
It's the TI evm kit, Power supply is enough, at the moment i dont run any motor yet. Cause it was the Laboration 1. Anyhow, I have not had this problem occur that often anymore.
Which EVM board? Did you set any breakpoint in the ISR code? You might try to reload the program and disable all of the breakpoints by clicking "view" on CCS menu, and select "breakpoints", and then "disable all breakpoints" on breakpoints window.
