Hello.
Section 24.4.7.6 of the TRM states that it supports MMC Specification v4.2.
Can you confirm if we can use later versions of this MMC specification with the AM3505?
Thanks.
Hello.
Thanks.
You will need to contact eMMC manufactures to confirm their devices are backwards compatible to a host controller designed for revision 4.2 of the eMMC standard.
You should also read and understand boot ROM requirements described in the MMC/SD Cards section of the TRM Initialization chapter if you plan to boot from eMMC.
Paul
