phc2sys fails to synchronize between CLOCK_REALTIME and PRU ETH ptp devices in Linux RT SDK 8.0:
root@am65xx-evm:~# phc2sys -s CLOCK_REALTIME -c /dev/ptp4 -O 0 -m
phc2sys[168.791]: /dev/ptp4 sys offset -585375821865600332 s0 freq +0
phc2sys[169.793]: /dev/ptp4 sys offset 5134053190471960488 s1 freq +10000000
phc2sys[170.793]: /dev/ptp4 sys offset 991607160 s2 freq +10000000
phc2sys[171.794]: /dev/ptp4 sys offset 1982135984 s2 freq +10000000
phc2sys[172.794]: /dev/ptp4 sys offset 2972654704 s2 freq +10000000
phc2sys[173.795]: /dev/ptp4 sys offset 3963195100 s2 freq +10000000
phc2sys[174.795]: /dev/ptp4 sys offset 4953715268 s2 freq +10000000
phc2sys[175.796]: /dev/ptp4 sys offset 5944279232 s2 freq +10000000
phc2sys[176.796]: /dev/ptp4 sys offset 6934800712 s2 freq +10000000
phc2sys[177.797]: /dev/ptp4 sys offset 7925320496 s2 freq +10000000
phc2sys[178.797]: /dev/ptp4 sys offset 8915830100 s2 freq +10000000
phc2sys[179.798]: /dev/ptp4 sys offset 9906343216 s2 freq +10000000
^Cphc2sys[179.842]: /dev/ptp4 sys offset -3504263346148290648 s2 freq -10000000 delay 0
root@am65xx-evm:~# phc2sys -c CLOCK_REALTIME -s /dev/ptp4 -O 0 -m
phc2sys[190.050]: CLOCK_REALTIME phc offset 5719428991085852536 s0 freq +0
phc2sys[191.050]: CLOCK_REALTIME phc offset -21270228068 s1 freq -100000000
phc2sys[192.088]: CLOCK_REALTIME phc offset -22222635708 s2 freq -100000000
phc2sys[193.103]: CLOCK_REALTIME phc offset -23155027412 s2 freq -100000000
phc2sys[194.111]: CLOCK_REALTIME phc offset -24080160312 s2 freq -100000000
phc2sys[195.115]: CLOCK_REALTIME phc offset -25002611112 s2 freq -100000000
phc2sys[196.117]: CLOCK_REALTIME phc offset -25922623756 s2 freq -100000000
phc2sys[197.142]: CLOCK_REALTIME phc offset -26863701616 s2 freq -100000000
phc2sys[198.165]: CLOCK_REALTIME phc offset -27802809124 s2 freq -100000000
phc2sys[199.174]: CLOCK_REALTIME phc offset -28729045260 s2 freq -100000000
phc2sys[200.182]: CLOCK_REALTIME phc offset -29655055708 s2 freq -100000000
^Cphc2sys[200.560]: clockcheck: clock jumped forward or running faster than expected!
phc2sys[200.560]: CLOCK_REALTIME phc offset 3504263326096007556 s0 freq -100000000 delay 0
root@am65xx-evm:~#
UART serial log is attached as phc2sys_fail_sdk_8_0.txt
It worked in SDK 7.3:
phc2sys[301.022]: /dev/ptp4 sys offset -1629743340889500378 s0 freq +0 delay 3140
phc2sys[302.024]: /dev/ptp4 sys offset -1629743340889500377 s1 freq +1 delay 3140
phc2sys[303.024]: /dev/ptp4 sys offset -3109 s2 freq -3108 delay 3150
phc2sys[304.024]: /dev/ptp4 sys offset -8 s2 freq -940 delay 3160
phc2sys[305.025]: /dev/ptp4 sys offset 936 s2 freq +2 delay 3155
phc2sys[306.025]: /dev/ptp4 sys offset 934 s2 freq +281 delay 3140
phc2sys[307.026]: /dev/ptp4 sys offset 651 s2 freq +278 delay 3150
phc2sys[308.026]: /dev/ptp4 sys offset 379 s2 freq +201 delay 3140
phc2sys[309.026]: /dev/ptp4 sys offset 189 s2 freq +125 delay 3160
phc2sys[310.027]: /dev/ptp4 sys offset 64 s2 freq +57 delay 3160
phc2sys[311.027]: /dev/ptp4 sys offset 3 s2 freq +15 delay 3145
phc2sys[312.027]: /dev/ptp4 sys offset -18 s2 freq -5 delay 3155
^Cphc2sys[312.713]: /dev/ptp4 sys offset -14 s2 freq -7 delay 3155
phc2sys[322.737]: CLOCK_REALTIME phc offset -42 s0 freq +0 delay 3140
phc2sys[323.738]: CLOCK_REALTIME phc offset -50 s2 freq -8 delay 3140
phc2sys[324.738]: CLOCK_REALTIME phc offset -46 s2 freq -54 delay 3150
phc2sys[325.739]: CLOCK_REALTIME phc offset -12 s2 freq -34 delay 3165
phc2sys[326.739]: CLOCK_REALTIME phc offset 29 s2 freq +4 delay 3140
phc2sys[327.740]: CLOCK_REALTIME phc offset 17 s2 freq +0 delay 3140
phc2sys[328.740]: CLOCK_REALTIME phc offset 4 s2 freq -8 delay 3150
phc2sys[329.741]: CLOCK_REALTIME phc offset 11 s2 freq +1 delay 3135
phc2sys[330.741]: CLOCK_REALTIME phc offset 8 s2 freq +1 delay 3140
phc2sys[331.742]: CLOCK_REALTIME phc offset -3 s2 freq -8 delay 3135
^Cphc2sys[332.544]: CLOCK_REALTIME phc offset 9 s2 freq +3 delay 3155
root@am65xx-evm:~#
UART serial log is attached as phc2sys_fail_sdk_7_3.txt
U-Boot SPL 2020.01-g2781231a33 (May 21 2021 - 23:11:09 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Lla')
SPL initial stack usage: 1452 bytes
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.4(release):2021.00.003-dirty
NOTICE: BL31: Built : 22:29:30, May 21 2021
U-Boot SPL 2020.01-g2781231a33 (May 21 2021 - 22:34:47 +0000)
pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
Detected: AM6-IDKAPPEVM rev A
Detected: SER-PCIE2LEVM rev A
U-Boot 2020.01-g2781231a33 (May 21 2021 - 22:34:47 +0000)
SoC: AM65X SR2.0
Model: Texas Instruments AM654 Base Board
Board: AM6-COMPROCEVM rev A
DRAM: 4 GiB
MMC: sdhci@4f80000: 0, sdhci@4fa0000: 1
Loading Environment from MMC... OK
In: serial
Out: serial
Err: serial
Net: eth3: pruss1_eth, eth2: pruss0_ethK3 CPSW: nuss_ver: 0x6BA00102 cpsw_ver: 0x6BA80102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Warning: ethernet@46000000 using MAC address from ROM
, eth0: ethernet@46000000, eth1: pruss2_eth
Hit any key to stop autoboot: 2 1 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
1011 bytes read in 5 ms (197.3 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
Using board_name = am65x
15527944 bytes read in 648 ms (22.9 MiB/s)
64338 bytes read in 9 ms (6.8 MiB/s)
11429 bytes read in 7 ms (1.6 MiB/s)
2333 bytes read in 6 ms (378.9 KiB/s)
Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] 000: printk: bootconsole [ns16550a0] enabled
[ 0.000000] 000: Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] 000: OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] 000: Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] 000: OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] 000: Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] 000: OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] 000: Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] 000: OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] 000: cma: Reserved 24 MiB at 0x00000000fe800000
[ 0.000000] 000: On node 0 totalpages: 788992
[ 0.000000] 000: DMA zone: 4096 pages used for memmap
[ 0.000000] 000: DMA zone: 0 pages reserved
[ 0.000000] 000: DMA zone: 262144 pages, LIFO batch:63
[ 0.000000] 000: DMA32 zone: 40 pages used for memmap
[ 0.000000] 000: DMA32 zone: 2560 pages, LIFO batch:0
[ 0.000000] 000: Normal zone: 8192 pages used for memmap
[ 0.000000] 000: Normal zone: 524288 pages, LIFO batch:63
[ 0.000000] 000: psci: probing for conduit method from DT.
[ 0.000000] 000: psci: PSCIv1.1 detected in firmware.
[ 0.000000] 000: psci: Using standard PSCI v0.2 function IDs
[ 0.000000] 000: psci: Trusted OS migration not required
[ 0.000000] 000: psci: SMC Calling Convention v1.0
[ 0.000000] 000: percpu: Embedded 18 pages/cpu s32960 r8192 d32576 u73728
[ 0.000000] 000: pcpu-alloc: s32960 r8192 d32576 u73728 alloc=18*4096
[ 0.000000] 000:
[ 0.000000] 000: [0]
[ 0.000000] 000: 0
[ 0.000000] 000: 1
[ 0.000000] 000: 2
[ 0.000000] 000: 3
[ 0.000000] 000:
[ 0.000000] 000: Detected VIPT I-cache on CPU0
[ 0.000000] 000: CPU features: detected: ARM erratum 845719
[ 0.000000] 000: CPU features: detected: GIC system register CPU interface
[ 0.000000] 000: Built 1 zonelists, mobility grouping on. Total pages: 776664
[ 0.000000] 000: Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),57216k@8m(ospi.rootfs),128k(ospi.phypattern) root=PARTUUID=99801634-02 rw rootfstype=ext4 rootwait
[ 0.000000] 000: Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes, linear)
[ 0.000000] 000: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] 000: mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] 000: software IO TLB: mapped [mem 0xbbfff000-0xbffff000] (64MB)
[ 0.000000] 000: Memory: 3944288K/3155968K available (9342K kernel code, 636K rwdata, 3632K rodata, 1472K init, 423K bss, 18446744073708738720K reserved, 24576K cma-reserved)
[ 0.000000] 000: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] 000: rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] 000: rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] 000: rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] 000: rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] 000: No expedited grace period (rcu_normal_after_boot).
[ 0.000000] 000: Tasks RCU enabled.
[ 0.000000] 000: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] 000: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] 000: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] 000: GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] 000: GICv3: 960 SPIs implemented
[ 0.000000] 000: GICv3: 0 Extended SPIs implemented
[ 0.000000] 000: GICv3: Distributor has no Range Selector support
[ 0.000000] 000: GICv3: 16 PPIs implemented
[ 0.000000] 000: GICv3: no VLPI support, no direct LPI support
[ 0.000000] 000: GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] 000: ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] 000: GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] 000: ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] 000: ITS@0x0000000001820000: allocated 524288 Devices @8f9c00000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] 000: ITS: using cache flushing for cmd queue
[ 0.000000] 000: GICv3: using LPI property table @0x00000008fa440000
[ 0.000000] 000: GIC: using cache flushing for LPI property table
[ 0.000000] 000: GICv3: CPU0: using allocated LPI pending table @0x00000008fa450000
[ 0.000000] 000: random: get_random_bytes called from start_kernel+0x2bc/0x430 with crng_init=0
[ 0.000000] 000: arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] 000: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] 000: sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.009122] 000: Console: colour dummy device 80x25
[ 0.014190] 000: Calibrating delay loop (skipped), value calculated using timer frequency..
[ 0.022850] 000: 400.00 BogoMIPS (lpj=800000)
[ 0.027325] 000: pid_max: default: 32768 minimum: 301
[ 0.032646] 000: LSM: Security Framework initializing
[ 0.037914] 000: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.045973] 000: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.056501] 000: ASID allocator initialised with 32768 entries
[ 0.062638] 000: rcu: Hierarchical SRCU implementation.
[ 0.068671] 000: Platform MSI: gic-its@1820000 domain created
[ 0.074893] 000: PCI/MSI: /bus@100000/interrupt-controller@1800000/gic-its@1820000 domain created
[ 0.084472] 000: smp: Bringing up secondary CPUs ...
[ 0.090899] 001: Detected VIPT I-cache on CPU1
[ 0.095489] 001: GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.102997] 001: GICv3: CPU1: using allocated LPI pending table @0x00000008fa460000
[ 0.110886] 001: CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.119522] 002: Detected VIPT I-cache on CPU2
[ 0.124123] 002: GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000
[ 0.131809] 002: GICv3: CPU2: using allocated LPI pending table @0x00000008fa470000
[ 0.139705] 002: CPU2: Booted secondary processor 0x0000000100 [0x410fd034]
[ 0.148277] 003: Detected VIPT I-cache on CPU3
[ 0.152855] 003: GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000
[ 0.160537] 003: GICv3: CPU3: using allocated LPI pending table @0x00000008fa480000
[ 0.168415] 003: CPU3: Booted secondary processor 0x0000000101 [0x410fd034]
[ 0.175717] 000: smp: Brought up 1 node, 4 CPUs
[ 0.180409] 000: SMP: Total of 4 processors activated.
[ 0.185707] 000: CPU features: detected: 32-bit EL0 Support
[ 0.191451] 000: CPU features: detected: CRC32 instructions
[ 0.208742] 000: CPU: All CPU(s) started at EL2
[ 0.213443] 000: alternatives: patching kernel code
[ 0.220254] 000: devtmpfs: initialized
[ 0.238178] 000: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.248679] 000: futex hash table entries: 1024 (order: 5, 131072 bytes, linear)
[ 0.257518] 000: pinctrl core: initialized pinctrl subsystem
[ 0.264491] 000: NET: Registered protocol family 16
[ 0.271661] 000: DMA: preallocated 256 KiB pool for atomic allocations
[ 0.279333] 000: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.314540] 001: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.321925] 001: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.329276] 001: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.336623] 001: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.345488] 001: cryptd: max_cpu_qlen set to 1000
[ 0.356608] 001: iommu: Default domain type: Translated
[ 0.362617] 001: SCSI subsystem initialized
[ 0.367779] 001: mc: Linux media interface: v0.10
[ 0.372693] 001: videodev: Linux video capture interface: v2.00
[ 0.378828] 001: pps_core: LinuxPPS API ver. 1 registered
[ 0.384390] 001: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.394252] 001: PTP clock support registered
[ 0.398773] 001: EDAC MC: Ver: 3.0.0
[ 0.403938] 000: FPGA manager framework
[ 0.408109] 000: Advanced Linux Sound Architecture Driver Initialized.
[ 0.415864] 001: clocksource: Switched to clocksource arch_sys_counter
[ 0.422755] 001: VFS: Disk quotas dquot_6.6.0
[ 0.427358] 001: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.443409] 001: thermal_sys: Registered thermal governor 'step_wise'
[ 0.450061] 001: thermal_sys: Registered thermal governor 'power_allocator'
[ 0.457866] 001: NET: Registered protocol family 2
[ 0.463732] 000: tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.473267] 000: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.482278] 000: TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear)
[ 0.492689] 000: TCP: Hash tables configured (established 32768 bind 32768)
[ 0.500177] 000: UDP hash table entries: 2048 (order: 6, 262144 bytes, linear)
[ 0.508022] 000: UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear)
[ 0.516530] 000: NET: Registered protocol family 1
[ 0.522263] 001: RPC: Registered named UNIX socket transport module.
[ 0.528833] 001: RPC: Registered udp transport module.
[ 0.534126] 001: RPC: Registered tcp transport module.
[ 0.539412] 001: RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.546489] 001: PCI: CLS 0 bytes, default 64
[ 0.552216] 001: hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.565932] 000: Initialise system trusted keyrings
[ 0.571199] 000: workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.587227] 000: squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.594539] 000: NFS: Registering the id_resolver key type
[ 0.600278] 000: Key type id_resolver registered
[ 0.605041] 000: Key type id_legacy registered
[ 0.609666] 000: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.617282] 000: 9p: Installing v9fs 9p2000 file system support
[ 0.643194] 000: Key type asymmetric registered
[ 0.647901] 000: Asymmetric key parser 'x509' registered
[ 0.653429] 000: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.661532] 000: io scheduler mq-deadline registered
[ 0.666656] 000: io scheduler kyber registered
[ 0.674758] 000: pinctrl-single 4301c000.pinmux: 70 pins, size 280
[ 0.681899] 000: pinctrl-single 11c000.pinmux: 185 pins, size 740
[ 0.688440] 000: pinctrl-single 11c2e8.pinmux: 9 pins, size 36
[ 0.702792] 001: k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.709673] 001: k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.721916] 001: Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.749674] 001: brd: module loaded
[ 0.765298] 001: loop: module loaded
[ 0.774225] 001: libphy: Fixed MDIO Bus: probed
[ 0.779714] 001: tun: Universal TUN/TAP device driver, 1.6
[ 0.786319] 001: igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 0.794854] 001: igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.801474] 001: sky2: driver version 1.30
[ 0.807410] 001: VFIO - User Level meta-driver version: 0.3
[ 0.814304] 001: i2c /dev entries driver
[ 0.820048] 001: sdhci: Secure Digital Host Controller Interface driver
[ 0.826865] 001: sdhci: Copyright(c) Pierre Ossman
[ 0.832641] 001: sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.840575] 001: ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: invalid resource
[ 0.850401] 001: optee: probing for conduit method from DT.
[ 0.856183] 001: optee: revision 3.11 (c4def2a8)
[ 0.861656] 001: optee: initialized driver
[ 0.868185] 001: NET: Registered protocol family 17
[ 0.873468] 001: 9pnet: Installing 9P2000 support
[ 0.878414] 001: Key type dns_resolver registered
[ [ 0 0..008083009509] ]0 00000:: B oroegtiisntg erLeindu txa sonks tphatyssi vcealr siCPoUn 10x0
0[0 00 0000.80093 1[015x4] 10000fd:0 L3o4a]di
ng compiled-in X.509 certificates
[ 0.913352] 000: k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.920431] 000: k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.933941] 000: ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: invalid resource
[ 0.942422] 000: ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Lla')
[ 1.008184] 000: random: fast init done
[ 1.032590] 000: omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.039749] 000: omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
[ 1.047007] 000: pca953x 2-0041: 2-0041 supply vcc not found, using dummy regulator
[ 1.055007] 000: pca953x 2-0041: using no AI
[ 1.080617] 000: pca953x 2-0021: 2-0021 supply vcc not found, using dummy regulator
[ 1.088588] 000: pca953x 2-0021: using no AI
[ 1.093853] 000: omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.101116] 000: omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.108192] 000: omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
[ 1.115128] 000: omap_i2c 2030000.i2c: bus 5 rev0.12 at 100 kHz
[ 1.122381] 000: ti-sci-intr bus@100000:bus@28380000:bus@42040000:interrupt-controller2: Interrupt Router 156 domain created
[ 1.134198] 000: ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 100 domain created
[ 1.143650] 000: ti-sci-intr bus@100000:navss@30800000:interrupt-controller1: Interrupt Router 182 domain created
[ 1.154609] 000: ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain -1 created
[ 1.176991] 000: keystone-pcie 5500000.pcie: host bridge /bus@100000/pcie@5500000 ranges:
[ 1.185473] 000: keystone-pcie 5500000.pcie: IO 0x10020000..0x1002ffff -> 0x00000000
[ 1.193748] 000: keystone-pcie 5500000.pcie: MEM 0x10030000..0x17ffffff -> 0x10030000
[ 2.202627] 000: keystone-pcie 5500000.pcie: Phy link never came up
[ 2.209313] 000: keystone-pcie 5500000.pcie: PCI host bridge to bus 0000:00
[ 2.216500] 000: pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.222608] 000: pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.229425] 000: pci_bus 0000:00: root bus resource [mem 0x10030000-0x17ffffff]
[ 2.236985] 000: pci 0000:00:00.0: [104c:b00c] type 01 class 0x060400
[ 2.243660] 000: pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[ 2.251083] 000: pci 0000:00:00.0: supports D1
[ 2.255674] 000: pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 2.270033] 000: pci 0000:00:00.0: BAR 6: assigned [mem 0x10030000-0x1003ffff pref]
[ 2.277937] 000: pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 2.284635] 000: pcieport 0000:00:00.0: PME: Signaling with IRQ 43
[ 2.291532] 000: pcieport 0000:00:00.0: AER: enabled with IRQ 43
[ 2.305501] 000: k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,160] sci-dev-id:195
[ 2.316016] 000: k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 2.323284] 000: k3-ringacc 2b800000.ringacc: RA Proxy rev. 66348100, num_proxies:64
[ 2.349400] 000: k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:818, gp-rings[304,464] sci-dev-id:187
[ 2.360019] 000: k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 2.367290] 000: k3-ringacc 3c000000.ringacc: RA Proxy rev. 66348100, num_proxies:64
[ 2.376354] 000: 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 8, base_baud = 6000000) is a 8250
[ 2.386879] 000: 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 21, base_baud = 3000000) is a 8250
[ 2.396245] 000: printk: console [ttyS2] enabled
[ 2.401019] 000: printk: bootconsole [ns16550a0] disabled
[ 2.412230] 000: 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 22, base_baud = 3000000) is a 8250
[ 2.413126] 000: 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 23, base_baud = 3000000) is a 8250
[ 2.467886] 000: davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.467909] 000: libphy: 46000f00.mdio: probed
[ 2.469440] 000: davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 2.469486] 000: am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00102, cpsw version 0x6BA80102 Ports: 2 quirks:00000000
[ 2.469556] 000: am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[ 2.472277] 000: am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 2.474020] 000: mmc0: CQHCI version 5.10
[ 2.515542] 000: mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[ 2.532684] 000: pca953x 0-0039: 0-0039 supply vcc not found, using dummy regulator
[ 2.532806] 000: pca953x 0-0039: using no AI
[ 2.557586] 000: omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 2.558108] 000: omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 2.562805] 000: ti-udma 285c0000.dma-controller: Channels: 96 (tchan: 48, rchan: 48, gp-rflow: 48)
[ 2.581651] 000: ti-udma 31150000.dma-controller: Channels: 267 (tchan: 119, rchan: 148, gp-rflow: 150)
[ 2.602850] 000: mmc0: Command Queue Engine enabled
[ 2.602874] 000: mmc0: new HS200 MMC card at address 0001
[ 2.603783] 000: mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 2.604154] 000: mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[ 2.604444] 000: mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[ 2.604694] 000: mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0)
[ 2.614964] 000: spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
[ 2.615000] 000: 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[ 2.615007] 000: Creating 8 MTD partitions on "47040000.spi.0":
[ 2.615016] 000: 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 2.616808] 000: 0x000000080000-0x000000280000 : "ospi.tispl"
[ 2.618397] 000: 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 2.620078] 000: 0x000000680000-0x0000006a0000 : "ospi.env"
[ 2.621714] 000: 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[ 2.623285] 000: 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[ 2.624983] 000: 0x000000800000-0x000003fe0000 : "ospi.rootfs"
[ 2.626607] 000: 0x000003fe0000-0x000004000000 : "ospi.phypattern"
[ 2.638224] 000: spi-nor spi9.0: n25q128a13 (16384 Kbytes)
[ 2.679886] 000: davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.679906] 000: libphy: 46000f00.mdio: probed
[ 2.681395] 000: davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 2.681441] 000: am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00102, cpsw version 0x6BA80102 Ports: 2 quirks:00000000
[ 2.683222] 000: am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 2.684062] 000: am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.684073] 000: am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.685232] 000: am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 2.690617] 000: mmc1: CQHCI version 5.10
[ 3.544085] 000: mmc1: SDHCI controller on 4fa0000.sdhci [4fa0000.sdhci] using ADMA 64-bit
[ 3.545282] 003: debugfs: Directory 'pd:121' with parent 'pm_genpd' already present!
[ 3.545354] 003: debugfs: Directory 'pd:120' with parent 'pm_genpd' already present!
[ 3.549152] 002: input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 3.549542] 002: hctosys: unable to open rtc device (rtc0)
[ 3.571799] 002: ALSA device list:
[ 3.571806] 002: No soundcards found.
[ 3.591970] 001: Waiting for root device PARTUUID=99801634-02...
[ 3.603168] 000: mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 3.604136] 000: mmcblk1: mmc1:aaaa SA08G 7.40 GiB
[ 3.606733] 000: mmcblk1: p1 p2
[ 3.706774] 001: EXT4-fs (mmcblk1p2): recovery complete
[ 3.708657] 001: EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.708751] 001: VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 3.711981] 001: devtmpfs: mounted
[ 3.713113] 001: Freeing unused kernel memory: 1472K
[ 3.713247] 001: Run /sbin/init as init process
[ 3.853766] 001: systemd[1]: System time before build time, advancing clock.
[ 3.909315] 001: NET: Registered protocol family 10
[ 3.910614] 001: Segment Routing with IPv6
[ 3.929595] 001: systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 3.930250] 001: systemd[1]: Detected architecture arm64.
Welcome to Arago 2020.09!
[ 3.989414] 002: systemd[1]: Set hostname to <am65xx-evm>.
[ 4.364321] 003: systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[ 4.491211] 001: random: systemd: uninitialized urandom read (16 bytes read)
[ 4.491529] 001: systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 4.491546] 001: systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 4.496703] 001: systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ OK ] Created slice system-serial\x2dgetty[ 4.544119] 000: random: systemd: uninitialized urandom read (16 bytes read)
.slice.
[ 4.546515] 000: systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.567537] 001: random: systemd: uninitialized urandom read (16 bytes read)
[ 4.569650] 001: systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ OK ] Started Dispatch Password …ts to C[ 4.596439] 000: systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Forward Password R…uests t[ 4.620292] 000: systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Paths.
[ 4.644214] 000: systemd[1]: Reached target Paths.
[ OK ] Reached target Remote File Systems 4.656077] 000: systemd[1]: Reached target Remote File Systems.
0m.
[ OK ] Reached target Slices.[ 4.680057] 001: systemd[1]: Reached target Slices.
[ OK ] Reached target Swap.
[ 4.700056] 000: systemd[1]: Reached target Swap.
[ OK ] Listening on RPCbind Server Activat[ 4.718931] 001: systemd[1]: Listening on RPCbind Server Activation Socket.
ion Socket.
[ OK ] Reached target RPC Port Mapper.[ 4.740132] 000: systemd[1]: Reached target RPC Port Mapper.
[ OK ] Listening on Process Core Dump Sock[ 4.767420] 001: systemd[1]: Listening on Process Core Dump Socket.
et.
[ OK ] Listening on initctl Compatibility N[ 4.788411] 000: systemd[1]: Listening on initctl Compatibility Named Pipe.
amed Pipe.
[ OK ] Listening on Journal Socket (/dev/l[ 4.821682] 001: systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
og).
[ 4.822615] 001: systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket.
[ 4.844970] 001: systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Network Service Netlin[ 4.856971] 001: systemd[1]: Listening on Network Service Netlink Socket.
k Socket.
[ OK ] Listening on udev Control Socket[ 4.880595] 000: systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Kernel Socket[ 4.904415] 001: systemd[1]: Listening on udev Kernel Socket.
[ 4.934710] 000: systemd[1]: Mounting Huge Pages File System...
Mounting POSIX Message Queue File System..[ 4.958390] 003: systemd[1]: Mounting POSIX Message Queue File System...
Mounting Kernel Debug File System...
[ 4.986562] 000: systemd[1]: Mounting Kernel Debug File System...
Mounting Temporary Directory (/tmp)...
[ 5.007378] 001: systemd[1]: Mounting Temporary Directory (/tmp)...
Starting Create list of st…odes for the curr[ 5.030759] 001: systemd[1]: Starting Create list of static device nodes for the current kernel...
ent kernel...
Starting Start psplash boot splash screen.[ 5.062089] 002: systemd[1]: Starting Start psplash boot splash screen...
[ OK ] Started Hardware RNG Entropy Gather[ 5.092857] 002: systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
er Daemon.
[ 5.123665] 001: systemd[1]: Starting RPC Bind...
[ 5.140453] 000: systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Starting Journal Service...
[ 5.149329] 000: systemd[1]: Starting Journal Service...
[ 5.179623] 001: systemd[1]: Starting Load Kernel Modules...
Starting Remount Root and Kernel File Systems 5.202344] 001: systemd[1]: Starting Remount Root and Kernel File Systems...
[0m...
[ 5.220616] 001: cryptodev: loading out-of-tree module taints kernel.
[ 5.235472] 001: cryptodev: driver 1.10 loaded.
Starting udev Coldplug all Devices...
[ 5.244935] 001: systemd[1]: Starting udev Coldplug all Devices...
[ 5.261289] 003: EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ OK ] Started RPC Bind.
[ 5.288521] 001: systemd[1]: Started RPC Bind.
[ OK ] Mounted Huge Pages File System.[ 5.304698] 001: systemd[1]: Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File Sy[ 5.328941] 001: systemd[1]: Mounted POSIX Message Queue File System.
stem.
[ OK ] Mounted Kernel Debug File System 5.353236] 001: systemd[1]: Mounted Kernel Debug File System.
m.
[ OK ] Mounted Temporary Directory (/tmp) 5.376892] 001: systemd[1]: Mounted Temporary Directory (/tmp).
[0m.
[ OK ] Started Journal Service.
[ 5.400974] 001: systemd[1]: Started Journal Service.
[ OK ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
Starting Apply Kernel Variables...
[ 5.608945] 001: systemd-journald[217]: Received client request to flush runtime journal.
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started udev Kernel Device Manager.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ 8.275973] 000: random: crng init done
[ 8.275991] 000: random: 7 urandom warning(s) missed due to ratelimiting
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ 11.436280] 000: ov5640 3-003c: 3-003c supply DOVDD not found, using dummy regulator
[ 11.448087] 000: ov5640 3-003c: 3-003c supply AVDD not found, using dummy regulator
[ 11.450726] 002: ov5640 3-003c: 3-003c supply DVDD not found, using dummy regulator
[ 11.492278] 002: [drm] Initialized pvr 1.17.4948957 20110701 for 7000000.gpu on minor 0
[ 11.504084] 000: ov5640 3-003c: ov5640_read_reg: error: reg=300a
[ 11.504103] 000: ov5640 3-003c: ov5640_check_chip_id: failed to read chip identifier
[ 11.529932] 002: ov5640: probe of 3-003c failed with error -121
[ 12.170611] 003: CAN device driver interface
[ 12.537209] 002: dwc3 4010000.usb: Failed to get clk 'ref': -2
[ 12.583589] 000: dwc3 4030000.usb: Failed to get clk 'ref': -2
[ 12.594018] 000: OF: graph: no port node found in /bus@100000/phy@4110000
[ 13.078356] 001: m_can_platform 40528000.mcan: m_can device registered (irq=15, version=32)
[ 13.147935] 000: davinci_mdio b032400.mdio: davinci mdio revision 1.7, bus freq 1000000
[ 13.147965] 000: libphy: b032400.mdio: probed
[ 13.389047] 000: davinci_mdio b032400.mdio: phy[0]: device b032400.mdio:00, driver TI DP83867
[ 13.389067] 000: davinci_mdio b032400.mdio: phy[3]: device b032400.mdio:03, driver TI DP83867
[ 13.580828] 000: m_can_platform 40568000.mcan: m_can device registered (irq=17, version=32)
[ 13.896958] 003: platform 41000000.r5f: configured R5F for remoteproc mode
[ 13.900697] 003: platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[ 14.034825] 003: remoteproc remoteproc0: 41000000.r5f is available
[ 14.038799] 003: remoteproc remoteproc0: powering up 41000000.r5f
[ 14.038823] 003: remoteproc remoteproc0: Booting fw image am65x-mcu-r5f0_0-fw, size 85292
[ 14.092131] 003: platform 41000000.r5f: booting R5F core using boot addr = 0x0
[ 14.092539] 003: remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[ 14.137296] 003: virtio_rpmsg_bus virtio0: rpmsg host is online
[ 14.137408] 003: remoteproc0#vdev0buffer: registered virtio0 (type 7)
[ 14.137419] 003: remoteproc remoteproc0: remote processor 41000000.r5f is now up
[ 14.147175] 000: virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 14.296904] 000: virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[ 15.455952] 001: davinci_mdio b132400.mdio: davinci mdio revision 1.7, bus freq 1000000
[ 15.455985] 001: libphy: b132400.mdio: probed
[ OK ] Started udev Coldplug all Devices.
[ 15.541065] 001: davinci_mdio b132400.mdio: phy[0]: device b132400.mdio:00, driver TI DP83867
[ 15.541085] 001: davinci_mdio b132400.mdio: phy[3]: device b132400.mdio:03, driver TI DP83867
[ OK ] Reached target System Initialization.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ 15.640764] 001: davinci_mdio b232400.mdio: davinci mdio revision 1.7, bus freq 1000000
[[ 15.640929] 001: libphy: b232400.mdio: probed
OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API.
[ OK ] Listening on dropbear.socket.
Starting Reboot and dump vmcore via kexec...
[ 16.061043] 002: davinci_mdio b232400.mdio: phy[0]: device b232400.mdio:00, driver TI DP83867
[ 16.061065] 002: davinci_mdio b232400.mdio: phy[3]: device b232400.mdio:03, driver TI DP83867
[ OK ] Listening on Docker Socket for the API.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Job spooling tools.
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started D-Bus System Message Bus.
Starting Print notice about GPLv3 packages...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
[ OK ] Started irqbalance daemon.
Starting rc.pvr.service...
Starting Login Service...
[ 16.736000] 002: PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[ OK ] Started Reboot and dump vmcore via kexec.
[ OK ] Started IPv6 Packet Filtering Framework.
[ OK ] Started IPv4 Packet Filtering Framework.
[ OK ] Started rc.pvr.service.
[ OK ] Reached target Network (Pre).
Starting Network Service...
NOTICE: This file system contains the following GPLv3 packages:
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
glmark2
gstreamer1.0-libav
gzip
less
libasm1
libbfd
libdw1
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp10
libidn2-0
libmpc3
libmpfr6
libreadline-dev
libreadline8
libunistring2
m4-dev
m4
make
nettle
parted
pdm-anomaly-detection
tar
which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ 19.424514] 000: remoteproc remoteproc1: b034000.pru is available
[ 19.424679] 000: pru-rproc b034000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@34000 probed successfully
[ 19.475012] 000: usbcore: registered new interface driver usbfs
[ 19.520459] 000: usbcore: registered new interface driver hub
[ 19.538325] 000: usbcore: registered new device driver usb
Starting weston.service...
[ 19.594418] 001: remoteproc remoteproc2: b004000.rtu is available
[ 19.594544] 001: pru-rproc b004000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@4000 probed successfully
[ 19.616721] 000: pru-rproc b00a000.txpru: IRQ vring not found
[ 19.616737] 000: pru-rproc b00a000.txpru: IRQ kick not found
[ 19.774432] 001: remoteproc remoteproc3: b00a000.txpru is available
[ 19.774553] 001: pru-rproc b00a000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@a000 probed successfully
[ 20.007457] 001: remoteproc remoteproc4: b038000.pru is available
[ 20.007596] 001: pru-rproc b038000.pru: PRU rproc node /bus@100000/icssg@b000000/pru@38000 probed successfully
[ 20.317266] 000: xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 20.321347] 000: xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[ 20.321516] 000: xhci-hcd xhci-hcd.2.auto: hcc params 0x0298fe6d hci version 0x110 quirks 0x0000000000010010
[ 20.322087] 000: remoteproc remoteproc5: b006000.rtu is available
[ 20.322190] 000: pru-rproc b006000.rtu: PRU rproc node /bus@100000/icssg@b000000/rtu@6000 probed successfully
[ 20.324236] 000: xhci-hcd xhci-hcd.2.auto: irq 1294, io mem 0x04010000
[ 20.324931] 000: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 20.324945] 000: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 20.324952] 000: usb usb1: Product: xHCI Host Controller
[ 20.324958] 000: usb usb1: Manufacturer: Linux 5.4.106-rt54-g519667b0d8 xhci-hcd
[ 20.324964] 000: usb usb1: SerialNumber: xhci-hcd.2.auto
[ 20.326638] 001: pru-rproc b00c000.txpru: IRQ vring not found
[ 20.326651] 001: pru-rproc b00c000.txpru: IRQ kick not found
[ 20.431156] 000: remoteproc remoteproc6: b00c000.txpru is available
[ 20.431273] 000: pru-rproc b00c000.txpru: PRU rproc node /bus@100000/icssg@b000000/txpru@c000 probed successfully
[ 20.531167] 000: remoteproc remoteproc7: b134000.pru is available
[ 20.531289] 000: pru-rproc b134000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@34000 probed successfully
[ 20.572175] 000: hub 1-0:1.0: USB hub found
[ 20.572304] 000: hub 1-0:1.0: 1 port detected
[ 20.627059] 000: remoteproc remoteproc8: b104000.rtu is available
[ 20.627219] 000: pru-rproc b104000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@4000 probed successfully
[ 20.634717] 000: pru-rproc b10a000.txpru: IRQ vring not found
[ 20.634730] 000: pru-rproc b10a000.txpru: IRQ kick not found
[ 20.672415] 000: remoteproc remoteproc9: b10a000.txpru is available
[ 20.672534] 000: pru-rproc b10a000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@a000 probed successfully
[ 20.693167] 000: xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 20.693207] 000: xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[ 20.693235] 000: xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[ 20.693365] 000: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 20.693549] 000: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 20.693560] 000: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 20.693567] 000: usb usb2: Product: xHCI Host Controller
[ 20.693573] 000: usb usb2: Manufacturer: Linux 5.4.106-rt54-g519667b0d8 xhci-hcd
[ 20.693580] 000: usb usb2: SerialNumber: xhci-hcd.2.auto
[ 20.762085] 000: remoteproc remoteproc10: b138000.pru is available
[ 20.762197] 000: pru-rproc b138000.pru: PRU rproc node /bus@100000/icssg@b100000/pru@38000 probed successfully
[ 20.865190] 002: remoteproc remoteproc11: b106000.rtu is available
[ 20.865312] 002: pru-rproc b106000.rtu: PRU rproc node /bus@100000/icssg@b100000/rtu@6000 probed successfully
[ 20.888890] 002: pru-rproc b10c000.txpru: IRQ vring not found
[ 20.888907] 002: pru-rproc b10c000.txpru: IRQ kick not found
[ 20.925389] 002: hub 2-0:1.0: USB hub found
[ 20.925469] 002: hub 2-0:1.0: 1 port detected
[ 20.937205] 002: remoteproc remoteproc12: b10c000.txpru is available
[ 20.937325] 002: pru-rproc b10c000.txpru: PRU rproc node /bus@100000/icssg@b100000/txpru@c000 probed successfully
[ 20.996950] 003: remoteproc remoteproc13: b234000.pru is available
[ 20.997066] 003: pru-rproc b234000.pru: PRU rproc node /bus@100000/icssg@b200000/pru@34000 probed successfully
[ 21.129478] 002: remoteproc remoteproc14: b204000.rtu is available
[ 21.129651] 002: pru-rproc b204000.rtu: PRU rproc node /bus@100000/icssg@b200000/rtu@4000 probed successfully
[ 21.134113] 002: pru-rproc b20a000.txpru: IRQ vring not found
[ 21.134127] 002: pru-rproc b20a000.txpru: IRQ kick not found
[ 21.174762] 000: remoteproc remoteproc15: b20a000.txpru is available
[ 21.175056] 000: pru-rproc b20a000.txpru: PRU rproc node /bus@100000/icssg@b200000/txpru@a000 probed successfully
[ 21.320949] 000: remoteproc remoteproc16: b238000.pru is available
[ 21.321100] 000: pru-rproc b238000.pru: PRU rproc node /bus@100000/icssg@b200000/pru@38000 probed successfully
[ 21.451784] 000: remoteproc remoteproc17: b206000.rtu is available
[ 21.452044] 000: pru-rproc b206000.rtu: PRU rproc node /bus@100000/icssg@b200000/rtu@6000 probed successfully
[ 21.458711] 000: pru-rproc b20c000.txpru: IRQ vring not found
[ 21.458725] 000: pru-rproc b20c000.txpru: IRQ kick not found
[ OK ] Started Print notice about GPLv3 packages.
[ 21.512820] 000: remoteproc remoteproc18: b20c000.txpru is available
[ 21.512980] 000: pru-rproc b20c000.txpru: PRU rproc node /bus@100000/icssg@b200000/txpru@c000 probed successfully
[ OK ] Started weston.service.
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ OK ] Created slice system-weston.slice.
[ OK ] Reached target Hardware activated USB gadget.
[ 21.968292] 000: input: gpio-decoder as /devices/platform/gpio-decoder/input/input1
Starting telnetd.service...
[ OK ] Started Network Service.
[ 22.000689] 001: TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[ 22.002970] 000: am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
Starting Wait for Network to be Configured...
[ 22.069978] 000: icssg-prueth pruss1_eth: TI PRU ethernet driver initialized: dual EMAC mode
Starting Network Name Resolution...
[ OK ] Started telnetd.service.
[ OK ] Found device /dev/mmcblk1p1.
[ 22.776622] 003: icssg-prueth pruss0_eth: TI PRU ethernet driver initialized: dual EMAC mode
Starting File System Check on /dev/mmcblk1p1...
[ 23.627959] 000: icssg-prueth pruss2_eth: TI PRU ethernet driver initialized: dual EMAC mode
[ OK ] Started Login Service.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
Starting Enable and configure wl18xx bluetooth stack...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
Starting Permit User Sessions...
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started File System Check on /dev/mmcblk1p1.
Mounting /run/media/mmcblk1p1...
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Getty on tty4.
[ OK ] Started Serial Getty on ttyS1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ OK ] Started Weston Wayland Compositor.
[ OK ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[ OK ] Mounted /run/media/mmcblk1p1.
[ OK ] Created slice User Slice of UID 0.
Starting User Runtime Directory /run/user/0...
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Started User Runtime Directory /run/user/0.
Starting User Manager for UID 0...
[ 29.216615] 002: remoteproc remoteproc1: powering up b034000.pru
[ 29.219667] 002: remoteproc remoteproc1: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 35544
[ 29.219941] 002: pru-rproc b034000.pru: configured system_events[159-0] = 00000000,00000000,00000000,00000000,01000000
[ 29.219956] 002: pru-rproc b034000.pru: configured intr_channels = 0x00000001 host_intr = 0x00000004
[ 29.219968] 002: remoteproc remoteproc1: remote processor b034000.pru is now up
[ 29.220005] 002: remoteproc remoteproc2: powering up b004000.rtu
[ 29.221070] 002: remoteproc remoteproc2: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 29080
[ 29.221108] 002: remoteproc remoteproc2: remote processor b004000.rtu is now up
[ 29.221136] 002: remoteproc remoteproc3: powering up b00a000.txpru
[ 29.222742] 002: remoteproc remoteproc3: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 32536
[ 29.222778] 002: remoteproc remoteproc3: remote processor b00a000.txpru is now up
[ 29.241876] 002: TI DP83867 b032400.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b032400.mdio:00, irq=POLL)
[ 29.242183] 002: net eth3: started
[ 29.416495] 003: remoteproc remoteproc4: powering up b038000.pru
[ 29.418765] 003: remoteproc remoteproc4: Booting fw image ti-pruss/am65x-sr2-pru1-prueth-fw.elf, size 35840
[ 29.418962] 003: pru-rproc b038000.pru: configured system_events[159-0] = 00000000,00000000,00000000,00000000,02000000
[ 29.418974] 003: pru-rproc b038000.pru: configured intr_channels = 0x00000002 host_intr = 0x00000008
[ 29.418986] 003: remoteproc remoteproc4: remote processor b038000.pru is now up
[ 29.419022] 003: remoteproc remoteproc5: powering up b006000.rtu
[ 29.420129] 003: remoteproc remoteproc5: Booting fw image ti-pruss/am65x-sr2-rtu1-prueth-fw.elf, size 28316
[ 29.420162] 003: remoteproc remoteproc5: remote processor b006000.rtu is now up
[ 29.420193] 003: remoteproc remoteproc6: powering up b00c000.txpru
[ 29.421167] 003: remoteproc remoteproc6: Booting fw image ti-pruss/am65x-sr2-txpru1-prueth-fw.elf, size 31160
[ 29.421196] 003: remoteproc remoteproc6: remote processor b00c000.txpru is now up
[ 29.425956] 003: TI DP83867 b032400.mdio:03: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b032400.mdio:03, irq=POLL)
[ 29.426272] 003: net eth4: started
[ 29.460684] 003: remoteproc remoteproc7: powering up b134000.pru
[ 29.460881] 003: remoteproc remoteproc7: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 35544
[ 29.461089] 003: pru-rproc b134000.pru: configured system_events[159-0] = 00000000,00000000,00000000,00000000,01000000
[ 29.461100] 003: pru-rproc b134000.pru: configured intr_channels = 0x00000001 host_intr = 0x00000004
[ 29.461112] 003: remoteproc remoteproc7: remote processor b134000.pru is now up
[ 29.461142] 003: remoteproc remoteproc8: powering up b104000.rtu
[ 29.461288] 003: remoteproc remoteproc8: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 29080
[ 29.461312] 003: remoteproc remoteproc8: remote processor b104000.rtu is now up
[ 29.461334] 003: remoteproc remoteproc9: powering up b10a000.txpru
[ 29.461448] 003: remoteproc remoteproc9: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 32536
[ 29.461473] 003: remoteproc remoteproc9: remote processor b10a000.txpru is now up
[ 29.465796] 003: TI DP83867 b132400.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b132400.mdio:00, irq=POLL)
[ 29.466103] 003: net eth1: started
[ 29.628592] 002: remoteproc remoteproc10: powering up b138000.pru
[ 29.628800] 002: remoteproc remoteproc10: Booting fw image ti-pruss/am65x-sr2-pru1-prueth-fw.elf, size 35840
[ 29.629011] 002: pru-rproc b138000.pru: configured system_events[159-0] = 00000000,00000000,00000000,00000000,02000000
[ 29.629022] 002: pru-rproc b138000.pru: configured intr_channels = 0x00000002 host_intr = 0x00000008
[ 29.629034] 002: remoteproc remoteproc10: remote processor b138000.pru is now up
[ 29.629066] 002: remoteproc remoteproc11: powering up b106000.rtu
[ 29.629213] 002: remoteproc remoteproc11: Booting fw image ti-pruss/am65x-sr2-rtu1-prueth-fw.elf, size 28316
[ 29.629236] 002: remoteproc remoteproc11: remote processor b106000.rtu is now up
[ 29.629256] 002: remoteproc remoteproc12: powering up b10c000.txpru
[ 29.629372] 002: remoteproc remoteproc12: Booting fw image ti-pruss/am65x-sr2-txpru1-prueth-fw.elf, size 31160
[ 29.629394] 002: remoteproc remoteproc12: remote processor b10c000.txpru is now up
[ 29.634587] 002: TI DP83867 b132400.mdio:03: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b132400.mdio:03, irq=POLL)
[ 29.634931] 002: net eth2: started
[ 29.709017] 002: remoteproc remoteproc16: powering up b238000.pru
[ 29.709211] 002: remoteproc remoteproc16: Booting fw image ti-pruss/am65x-sr2-pru1-prueth-fw.elf, size 35840
[ 29.709439] 002: pru-rproc b238000.pru: configured system_events[159-0] = 00000000,00000000,00000000,00000000,02000000
[ 29.709451] 002: pru-rproc b238000.pru: configured intr_channels = 0x00000002 host_intr = 0x00000008
[ 29.709463] 002: remoteproc remoteproc16: remote processor b238000.pru is now up
[ 29.709495] 002: remoteproc remoteproc17: powering up b206000.rtu
[ 29.709614] 002: remoteproc remoteproc17: Booting fw image ti-pruss/am65x-sr2-rtu1-prueth-fw.elf, size 28316
[ 29.709638] 002: remoteproc remoteproc17: remote processor b206000.rtu is now up
[ 29.709658] 002: remoteproc remoteproc18: powering up b20c000.txpru
[ 29.709770] 002: remoteproc remoteproc18: Booting fw image ti-pruss/am65x-sr2-txpru1-prueth-fw.elf, size 31160
[ 29.709792] 002: remoteproc remoteproc18: remote processor b20c000.txpru is now up
[ 29.714220] 002: TI DP83867 b232400.mdio:03: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b232400.mdio:03, irq=POLL)
[ 29.714574] 002: net eth6: started
[ 29.760630] 002: remoteproc remoteproc13: powering up b234000.pru
[ 29.760844] 002: remoteproc remoteproc13: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 35544
[ 29.761064] 002: pru-rproc b234000.pru: configured system_events[159-0] = 00000000,00000000,00000000,00000000,01000000
[ 29.761075] 002: pru-rproc b234000.pru: configured intr_channels = 0x00000001 host_intr = 0x00000004
[ 29.761087] 002: remoteproc remoteproc13: remote processor b234000.pru is now up
[ 29.761120] 002: remoteproc remoteproc14: powering up b204000.rtu
[ 29.761240] 002: remoteproc remoteproc14: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 29080
[ 29.761267] 002: remoteproc remoteproc14: remote processor b204000.rtu is now up
[ 29.761291] 002: remoteproc remoteproc15: powering up b20a000.txpru
[ 29.761401] 002: remoteproc remoteproc15: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 32536
[ 29.761425] 002: remoteproc remoteproc15: remote processor b20a000.txpru is now up
[ 29.765756] 002: TI DP83867 b232400.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b232400.mdio:00, irq=POLL)
[ 29.766058] 002: net eth5: started
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am65xx-evm ttyS2
Arago 2020.09 am65xx-evm ttyS2
am65xx-evm login: [ 143.097467] 003: Initializing XFRM netlink socket
[ 144.231818] 001: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 144.237171] 001: Bridge firewalling registered
am65xx-evm login: root
Last login: Mon Aug 23 18:29:03 UTC 2021
root@am65xx-evm:~#
U-Boot SPL 2021.01-g53e79d0e89 (Aug 07 2021 - 15:00:28 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
SPL initial stack usage: 1416 bytes
NOTICE: BL31: v2.5(release):08.00.00.004-dirty
NOTICE: BL31: Built : 14:11:00, Aug 7 2021
U-Boot SPL 2021.01-g53e79d0e89 (Aug 07 2021 - 14:24:44 +0000)
Detected: Silicon SR2.0
i2c_omap i2c@42120000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
U-Boot 2021.01-g53e79d0e89 (Aug 07 2021 - 14:24:44 +0000)
SoC: AM65X SR2.0
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Net: am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00102 cpsw_ver: 0x6BA80102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
eth0: ethernet@46000000, eth1: icssg2-eth
Failed to load 'boot.scr'
1011 bytes read in 3 ms (329.1 KiB/s)
Running uenvcmd ...
18092544 bytes read in 751 ms (23 MiB/s)
63487 bytes read in 7 ms (8.6 MiB/s)
11308 bytes read in 5 ms (2.2 MiB/s)
2333 bytes read in 4 ms (569.3 KiB/s)
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.10.41-rt39-g0701a5b58c (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT_RT Sat Aug 7 14:52:48 UTC 2021
[ 0.000000] Machine model: Texas Instruments AM654 Base Board
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a20fffff]
[ 0.000000] node 0: [mem 0x00000000a2100000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] On node 0 totalpages: 1048576
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 8192 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:63
[ 0.000000] cma: Reserved 24 MiB at 0x00000000fe800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 18 pages/cpu s34752 r8192 d30784 u73728
[ 0.000000] pcpu-alloc: s34752 r8192 d30784 u73728 alloc=18*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),57216k@8m(ospi.rootfs),128k(ospi.phypattern) root=PARTUUID=abe6aaee-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fa800000-0x00000000fe800000] (64MB)
[ 0.000000] Memory: 3946848K/4194304K available (10560K kernel code, 1156K rwdata, 4092K rodata, 1728K init, 437K bss, 222880K reserved, 24576K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000880040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
[ 0.000000] random: get_random_bytes called from start_kernel+0x330/0x4d8 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008694] Console: colour dummy device 80x25
[ 0.013315] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.024039] pid_max: default: 32768 minimum: 301
[ 0.028902] LSM: Security Framework initializing
[ 0.033721] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.041337] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.051562] rcu: Hierarchical SRCU implementation.
[ 0.057078] Platform MSI: msi-controller@1820000 domain created
[ 0.063477] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.072922] EFI services will not be available.
[ 0.077931] smp: Bringing up secondary CPUs ...
[ 0.083789] Detected VIPT I-cache on CPU1
[ 0.087936] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.094999] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
[ 0.102464] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.110615] Detected VIPT I-cache on CPU2
[ 0.114780] GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000
[ 0.122027] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
[ 0.129500] CPU2: Booted secondary processor 0x0000000100 [0x410fd034]
[ 0.137578] Detected VIPT I-cache on CPU3
[ 0.141717] GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000
[ 0.148955] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
[ 0.156401] CPU3: Booted secondary processor 0x0000000101 [0x410fd034]
[ 0.163276] smp: Brought up 1 node, 4 CPUs
[ 0.167516] SMP: Total of 4 processors activated.
[ 0.172363] CPU features: detected: 32-bit EL0 Support
[ 0.177655] CPU features: detected: CRC32 instructions
[ 0.197885] CPU: All CPU(s) started at EL2
[ 0.202131] alternatives: patching kernel code
[ 0.208206] devtmpfs: initialized
[ 0.225796] KASLR disabled due to lack of seed
[ 0.230612] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.240635] futex hash table entries: 1024 (order: 5, 131072 bytes, linear)
[ 0.249071] pinctrl core: initialized pinctrl subsystem
[ 0.255117] DMI not present or invalid.
[ 0.259698] NET: Registered protocol family 16
[ 0.266536] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.274030] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.282423] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.291292] thermal_sys: Registered thermal governor 'step_wise'
[ 0.292072] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.305343] ASID allocator initialised with 65536 entries
[ 0.362114] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.369054] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.376012] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.382895] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.391419] cryptd: max_cpu_qlen set to 1000
[ 0.401038] k3-chipinfo 43000014.chipid: Family:AM65X rev:SR2.0 JTAGID[0x1bb5a02f] Detected
[ 0.410608] vcc3v3_io: supplied by evm_12v0
[ 0.416201] iommu: Default domain type: Translated
[ 0.421829] SCSI subsystem initialized
[ 0.426547] mc: Linux media interface: v0.10
[ 0.431041] videodev: Linux video capture interface: v2.00
[ 0.436880] pps_core: LinuxPPS API ver. 1 registered
[ 0.441980] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.451372] PTP clock support registered
[ 0.455438] EDAC MC: Ver: 3.0.0
[ 0.460237] FPGA manager framework
[ 0.463869] Advanced Linux Sound Architecture Driver Initialized.
[ 0.471364] clocksource: Switched to clocksource arch_sys_counter
[ 0.477898] VFS: Disk quotas dquot_6.6.0
[ 0.482005] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.498079] NET: Registered protocol family 2
[ 0.502970] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.513252] tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.522346] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.530920] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear)
[ 0.540918] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.547944] UDP hash table entries: 2048 (order: 6, 262144 bytes, linear)
[ 0.555331] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear)
[ 0.563481] NET: Registered protocol family 1
[ 0.568823] RPC: Registered named UNIX socket transport module.
[ 0.574955] RPC: Registered udp transport module.
[ 0.579788] RPC: Registered tcp transport module.
[ 0.584618] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.591237] PCI: CLS 0 bytes, default 64
[ 0.596654] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.611850] Initialise system trusted keyrings
[ 0.616692] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.630712] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.637491] NFS: Registering the id_resolver key type
[ 0.642751] Key type id_resolver registered
[ 0.647065] Key type id_legacy registered
[ 0.651306] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.658217] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.666117] 9p: Installing v9fs 9p2000 file system support
[ 0.725457] Key type asymmetric registered
[ 0.729706] Asymmetric key parser 'x509' registered
[ 0.734776] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.742389] io scheduler mq-deadline registered
[ 0.747070] io scheduler kyber registered
[ 0.754605] pinctrl-single 4301c000.pinctrl: 70 pins, size 280
[ 0.761350] pinctrl-single 11c000.pinctrl: 185 pins, size 740
[ 0.767498] pinctrl-single 11c2e8.pinctrl: 9 pins, size 36
[ 0.781334] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.787778] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.799606] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.829144] brd: module loaded
[ 0.844202] loop: module loaded
[ 0.848578] megasas: 07.714.04.00-rc1
[ 0.856579] libphy: Fixed MDIO Bus: probed
[ 0.862695] tun: Universal TUN/TAP device driver, 1.6
[ 0.868917] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.875407] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.881577] sky2: driver version 1.30
[ 0.886957] VFIO - User Level meta-driver version: 0.3
[ 0.893527] i2c /dev entries driver
[ 0.898958] sdhci: Secure Digital Host Controller Interface driver
[ 0.905321] sdhci: Copyright(c) Pierre Ossman
[ 0.910578] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.918266] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: invalid resource
[ 0.925973] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.934390] optee: probing for conduit method.
[ 0.938994] optee: revision 3.12 (3d47a131)
[ 0.939618] optee: initialized driver
[ 0.950604] NET: Registered protocol family 17
[ 0.955468] 9pnet: Installing 9P2000 support
[ 0.959973] Key type dns_resolver registered
[ 0.964821] printk: bootconsole [ns16550a0]: printing thread started
[ 0.964908] Loading compiled-in X.509 certificates
[ 0.978102] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.978427] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.985901] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: invalid resource
[ 0.986414] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
[ 1.059320] random: fast init done
[ 1.080666] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.082006] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
[ 1.084250] pca953x 2-0021: supply vcc not found, using dummy regulator
[ 1.084428] pca953x 2-0021: using no AI
[ 1.108242] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.109496] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.110625] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
[ 1.111742] omap_i2c 2030000.i2c: bus 5 rev0.12 at 100 kHz
[ 1.113124] ti-sci-intr bus@100000:bus@28380000:bus@42040000:interrupt-controller2: Interrupt Router 156 domain created
[ 1.113393] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 100 domain created
[ 1.113636] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 182 domain created
[ 1.114059] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 179 created
[ 1.129277] keystone-pcie 5500000.pcie: host bridge /bus@100000/pcie@5500000 ranges:
[ 1.129317] OF: /bus@100000/pcie@5500000: Missing device_type
[ 1.129353] keystone-pcie 5500000.pcie: IO 0x0010020000..0x001002ffff -> 0x0000000000
[ 1.129388] keystone-pcie 5500000.pcie: MEM 0x0010030000..0x0017ffffff -> 0x0010030000
[ 2.130064] keystone-pcie 5500000.pcie: Phy link never came up
[ 2.130331] keystone-pcie 5500000.pcie: PCI host bridge to bus 0000:00
[ 2.130345] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.130356] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.130393] pci_bus 0000:00: root bus resource [mem 0x10030000-0x17ffffff]
[ 2.130452] pci 0000:00:00.0: [104c:b00c] type 01 class 0x060400
[ 2.130476] pci 0000:00:00.0: reg 0x10: �������������j�����2����u5R�[ 2.130494] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[ 12.348516] printk: console [ttyS2]: printing thread started
[ 2.130578] pci 0000:00:00.0: supports D1
[ 12.348537] printk: console [ttyS2] enabled
[ 12.348544] printk: bootconsole [ns16550a0] disabled
[ 12.365240] printk: bootconsole [ns16550a0]: printing thread stopped
[ 12.366551] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 30, base_baud = 3000000) is a 8250
[ 12.367671] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 31, base_baud = 3000000) is a 8250
[ 12.423398] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 12.423426] libphy: 46000f00.mdio: probed
[ 12.425938] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 12.426076] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00102, cpsw version 0x6BA80102 Ports: 2 quirks:00000000
[ 12.429289] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 12.431883] mmc0: CQHCI version 5.10
[ 12.447398] pca953x 0-0039: supply vcc not found, using dummy regulator
[ 12.447612] pca953x 0-0039: using no AI
[ 12.473268] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 12.473598] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 12.473930] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 12.476360] ti-udma 285c0000.dma-controller: Channels: 28 (tchan: 14, rchan: 14, gp-rflow: 16)
[ 12.484110] ti-udma 31150000.dma-controller: Channels: 119 (tchan: 53, rchan: 66, gp-rflow: 64)
[ 12.498200] spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
[ 12.498244] 8 cmdlinepart partitions found on MTD device 47040000.spi.0
[ 12.498252] Creating 8 MTD partitions on "47040000.spi.0":
[ 12.498260] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 12.500082] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 12.501709] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 12.503249] 0x000000680000-0x0000006a0000 : "ospi.env"
[ 12.504951] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[ 12.506489] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[ 12.508093] 0x000000800000-0x000003fe0000 : "ospi.rootfs"
[ 12.509684] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
[ 12.521915] spi-nor spi9.0: n25q128a13 (16384 Kbytes)
[ 12.560412] mmc0: Command Queue Engine enabled
[ 12.560440] mmc0: new HS200 MMC card at address 0001
[ 12.561315] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 12.561579] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[ 12.561846] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[ 12.562144] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[ 12.563437] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 12.563471] libphy: 46000f00.mdio: probed
[ 12.566271] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 12.566452] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00102, cpsw version 0x6BA80102 Ports: 2 quirks:00000000
[ 12.568513] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 12.569450] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 12.569462] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 12.570635] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 12.574554] vdd_mmc1_sd: supplied by vcc3v3_io
[ 12.575909] debugfs: Directory 'pd:121' with parent 'pm_genpd' already present!
[ 12.575980] debugfs: Directory 'pd:120' with parent 'pm_genpd' already present!
[ 12.576643] mmc1: CQHCI version 5.10
[ 12.579671] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 12.600850] ALSA device list:
[ 12.600860] No soundcards found.
[ 13.500454] mmc1: SDHCI controller on 4fa0000.mmc [4fa0000.mmc] using ADMA 64-bit
[ 13.501043] Waiting for root device PARTUUID=abe6aaee-02...
[ 13.556938] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 13.557783] mmcblk1: mmc1:aaaa SC32G 29.7 GiB
[ 13.560419] mmcblk1: p1 p2
[ 13.633916] EXT4-fs (mmcblk1p2): recovery complete
[ 13.634717] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 13.634816] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 13.637216] devtmpfs: mounted
[ 13.638589] Freeing unused kernel memory: 1728K
[ 13.638756] Run /sbin/init as init process
[ 13.785915] systemd[1]: System time before build time, advancing clock.
[ 13.838687] NET: Registered protocol family 10
[ 13.839912] Segment Routing with IPv6
[ 13.859753] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 13.860449] systemd[1]: Detected architecture arm64.
[ 13.933196] systemd[1]: Set hostname to <am65xx-evm>.
[ 14.316701] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[ 14.439744] random: systemd: uninitialized urandom read (16 bytes read)
[ 14.440081] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 14.440101] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 14.445125] systemd[1]: Created slice system-getty.slice.
[ 14.459707] random: systemd: uninitialized urandom read (16 bytes read)
[ 14.461984] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 14.539562] random: systemd: uninitialized urandom read (16 bytes read)
[ 14.541561] systemd[1]: Created slice User and Session Slice.
[ 14.559928] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 14.595785] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 14.623322] systemd[1]: Reached target Paths.
[ 14.635568] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 14.659528] systemd[1]: Reached target Slices.
[ 14.671563] systemd[1]: Reached target Swap.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 14.700416] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 14.715665] systemd[1]: Reached target RPC Port Mapper.
[ 14.740417] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 14.763917] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on Journal Socket (/dev/log).
[ 14.792689] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 14.793639] systemd[1]: Listening on Journal Socket (/dev/log).
[ 14.816241] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 14.844382] systemd[1]: Listening on Network Service Netlink Socket.
[ 14.860113] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on udev Kernel Socket.
[ 14.888007] systemd[1]: Listening on udev Kernel Socket.
[ 14.915790] systemd[1]: Mounting Huge Pages File System...
[ 14.939645] systemd[1]: Mounting POSIX Message Queue File System...
[ 14.962242] systemd[1]: Mounting Kernel Debug File System...
[ 14.982714] systemd[1]: Mounting Temporary Directory (/tmp)...
Starting Create list of st…odes for the curr[ 15.001934] systemd[1]: Starting Create list of static device nodes for the current kernel...
ent kernel...
Starting Start psplash boot splash screen.[ 15.033827] systemd[1]: Starting Start psplash boot splash screen...
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ 15.064374] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[ 15.086598] systemd[1]: Starting RPC Bind...
[ 15.095890] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 15.104110] systemd[1]: Starting Journal Service...
[ 15.135053] systemd[1]: Starting Load Kernel Modules...
[ 15.166275] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 15.169935] cryptodev: loading out-of-tree module taints kernel.
[ 15.179867] cryptodev: driver 1.10 loaded.
[ 15.213092] systemd[1]: Starting udev Coldplug all Devices...
[ 15.231882] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 15.246102] systemd[1]: Started RPC Bind.
[ 15.265350] systemd[1]: Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File Sy[ 15.285702] systemd[1]: Mounted POSIX Message Queue File System.
stem.
[ OK ] Mounted Kernel Debug File System.
[ 15.317237] systemd[1]: Mounted Kernel Debug File System.
[ 15.341907] systemd[1]: Started Journal Service.
[ OK ] Mounted Temporary Directory (/tmp).
[ 15.569676] systemd-journald[213]: Received client request to flush runtime journal.
[ 18.263465] random: crng init done
[ 18.263484] random: 7 urandom warning(s) missed due to ratelimiting
[ OK ] Listening on D-Bus System Message Bus Socket.
[ 21.176074] [drm] Initialized pvr 1.17.4948957 20110701 for 7000000.gpu on minor 0
Starting Telephony service...
[ 21.485221] cal 6f03000.cal: Neither port is configured, no point in staying up
[ OK ] Started Telephony service.
[ 21.754469] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[ 21.914274] Bluetooth: Core ver 2.22
[ 21.914438] NET: Registered protocol family 31
[ 21.914445] Bluetooth: HCI device and connection manager initialized
[ 21.914471] Bluetooth: HCI socket layer initialized
[ 21.914485] Bluetooth: L2CAP socket layer initialized
[ 21.914514] Bluetooth: SCO socket layer initialized
[ 22.007453] davinci_mdio b032400.mdio: davinci mdio revision 1.7, bus freq 1000000
[ 22.007489] libphy: b032400.mdio: probed
[ 22.328907] davinci_mdio b032400.mdio: phy[0]: device b032400.mdio:00, driver TI DP83867
[ 22.328937] davinci_mdio b032400.mdio: phy[3]: device b032400.mdio:03, driver TI DP83867
[ 22.373382] CAN device driver interface
[ 22.762692] m_can_platform 40528000.mcan: m_can device registered (irq=23, version=32)
[ 22.852706] m_can_platform 40568000.mcan: m_can device registered (irq=25, version=32)
[ 22.969683] platform 41000000.r5f: configured R5F for remoteproc mode
[ 22.992337] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[ 23.069398] remoteproc remoteproc0: 41000000.r5f is available
[ 23.074744] remoteproc remoteproc0: powering up 41000000.r5f
[ 23.074770] remoteproc remoteproc0: Booting fw image am65x-mcu-r5f0_0-fw, size 65268
[ 23.110913] remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[ 23.318968] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 23.319177] remoteproc0#vdev0buffer: registered virtio0 (type 7)
[ 23.319193] remoteproc remoteproc0: remote processor 41000000.r5f is now up
[ 23.330611] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 23.380826] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[ 23.431465] davinci_mdio b132400.mdio: davinci mdio revision 1.7, bus freq 1000000
[ 23.431496] libphy: b132400.mdio: probed
[ 23.919746] davinci_mdio b132400.mdio: phy[0]: device b132400.mdio:00, driver TI DP83867
[ 23.919772] davinci_mdio b132400.mdio: phy[3]: device b132400.mdio:03, driver TI DP83867
[ 24.115421] davinci_mdio b232400.mdio: davinci mdio revision 1.7, bus freq 1000000
[ 24.115454] libphy: b232400.mdio: probed
[ 24.539501] davinci_mdio b232400.mdio: phy[0]: device b232400.mdio:00, driver TI DP83867
[ 24.539531] davinci_mdio b232400.mdio: phy[3]: device b232400.mdio:03, driver TI DP83867
[ 24.564977] remoteproc remoteproc1: b034000.pru is available
[ 24.566671] remoteproc remoteproc2: b004000.rtu is available
[ 24.567189] remoteproc remoteproc3: b00a000.txpru is available
[ 24.567728] remoteproc remoteproc4: b038000.pru is available
[ 24.568223] remoteproc remoteproc5: b006000.rtu is available
[ 24.568721] remoteproc remoteproc6: b00c000.txpru is available
[ 24.569279] remoteproc remoteproc7: b134000.pru is available
[ 24.569795] remoteproc remoteproc8: b104000.rtu is available
[ 24.570295] remoteproc remoteproc9: b10a000.txpru is available
[ 24.573805] remoteproc remoteproc10: b138000.pru is available
[ OK ] Started Getty on tty1.[ 24.587699] remoteproc remoteproc11: b106000.rtu is available
[ 24.654174] remoteproc remoteproc12: b10c000.txpru is available
[ 24.664007] remoteproc remoteproc13: b234000.pru is available
[ 24.665700] remoteproc remoteproc14: b204000.rtu is available
[ 24.666156] remoteproc remoteproc15: b20a000.txpru is available
[ 24.668821] remoteproc remoteproc16: b238000.pru is available
[ OK ] Started Serial Getty on ttyS1.[ 24.670191] remoteproc remoteproc17: b206000.rtu is available
[ 24.670769] remoteproc remoteproc18: b20c000.txpru is available
[ 25.571953] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[ 25.575041] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[ 30.699456] OF: graph: no port node found in /bus@100000/phy@4110000
[ 30.743635] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
_____ _____ _ _
|___| |___|
am65xx-evm login: ***************************************************************
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
glmark2
gstreamer1.0-libav-dev
gstreamer1.0-libav
gzip
less
libasm1
libbfd
libdw1
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp-dev
libgmp10
libgmpxx4
libidn2-0
libidn2-dev
libmpc3
libmpfr6
libreadline-dev
libreadline8
libunistring-dev
libunistring2
m4-dev
m4
make
nettle-dev
nettle
parted
python3-rfc3987
python3-strict-rfc3339
tar
which
zeromq
[ 33.466571] icssg-prueth icssg0-eth: TI PRU ethernet driver initialized: dual EMAC mode
[ 33.914334] usbcore: registered new interface driver usbfs
[ 33.950618] usbcore: registered new interface driver hub
[ 33.962407] usbcore: registered new device driver usb
[ 34.045634] icssg-prueth icssg2-eth: TI PRU ethernet driver initialized: dual EMAC mode
[ 34.405753] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 34.414964] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[ 34.415136] xhci-hcd xhci-hcd.2.auto: hcc params 0x0298fe6d hci version 0x110 quirks 0x0000000000010010
[ 34.432887] xhci-hcd xhci-hcd.2.auto: irq 594, io mem 0x04010000
[ 34.433483] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 34.433498] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 34.433507] usb usb1: Product: xHCI Host Controller
[ 34.433514] usb usb1: Manufacturer: Linux 5.10.41-rt39-g0701a5b58c xhci-hcd
[ 34.433521] usb usb1: SerialNumber: xhci-hcd.2.auto
[ 34.524077] icssg-prueth icssg1-eth: TI PRU ethernet driver initialized: dual EMAC mode
[ 34.878418] hub 1-0:1.0: USB hub found
[ 34.878736] hub 1-0:1.0: 1 port detected
[ 35.050812] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 35.050857] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[ 35.050885] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[ 35.051057] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 35.051404] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 35.051421] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 35.051430] usb usb2: Product: xHCI Host Controller
[ 35.051437] usb usb2: Manufacturer: Linux 5.10.41-rt39-g0701a5b58c xhci-hcd
[ 35.051445] usb usb2: SerialNumber: xhci-hcd.2.auto
[ 35.083080] remoteproc remoteproc4: powering up b038000.pru
[ 35.087608] remoteproc remoteproc4: Booting fw image ti-pruss/am65x-sr2-pru1-prueth-fw.elf, size 36588
[ 35.087655] remoteproc remoteproc4: unsupported resource 5
[ 35.087686] remoteproc remoteproc4: remote processor b038000.pru is now up
[ 35.087724] remoteproc remoteproc5: powering up b006000.rtu
[ 35.088823] remoteproc remoteproc5: Booting fw image ti-pruss/am65x-sr2-rtu1-prueth-fw.elf, size 29184
[ 35.088866] remoteproc remoteproc5: remote processor b006000.rtu is now up
[ 35.088894] remoteproc remoteproc6: powering up b00c000.txpru
[ 35.089947] remoteproc remoteproc6: Booting fw image ti-pruss/am65x-sr2-txpru1-prueth-fw.elf, size 34552
[ 35.089987] remoteproc remoteproc6: remote processor b00c000.txpru is now up
[ 35.095223] icssg-prueth icssg0-eth: settime timeout
[ 35.152221] pps pps0: new PPS source ptp2
[ 35.185200] TI DP83867 b032400.mdio:03: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b032400.mdio:03, irq=POLL)
[ 35.185500] net eth2: started
[ 35.274913] hub 2-0:1.0: USB hub found
[ 35.275019] hub 2-0:1.0: 1 port detected
[ 35.320096] remoteproc remoteproc1: powering up b034000.pru
[ 35.323677] remoteproc remoteproc1: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 36316
[ 35.323718] remoteproc remoteproc1: unsupported resource 5
[ 35.323749] remoteproc remoteproc1: remote processor b034000.pru is now up
[ 35.323789] remoteproc remoteproc2: powering up b004000.rtu
[ 35.324989] remoteproc remoteproc2: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 29944
[ 35.325036] remoteproc remoteproc2: remote processor b004000.rtu is now up
[ 35.325064] remoteproc remoteproc3: powering up b00a000.txpru
[ 35.326197] remoteproc remoteproc3: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 35916
[ 35.326247] remoteproc remoteproc3: remote processor b00a000.txpru is now up
[ 35.329157] TI DP83867 b032400.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b032400.mdio:00, irq=POLL)
[ 35.329477] net eth1: started
[ 35.800007] remoteproc remoteproc13: powering up b234000.pru
[ 35.800269] remoteproc remoteproc13: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 36316
[ 35.800301] remoteproc remoteproc13: unsupported resource 5
[ 35.800332] remoteproc remoteproc13: remote processor b234000.pru is now up
[ 35.800366] remoteproc remoteproc14: powering up b204000.rtu
[ 35.800539] remoteproc remoteproc14: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 29944
[ 35.800573] remoteproc remoteproc14: remote processor b204000.rtu is now up
[ 35.800597] remoteproc remoteproc15: powering up b20a000.txpru
[ 35.800734] remoteproc remoteproc15: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 35916
[ 35.800775] remoteproc remoteproc15: remote processor b20a000.txpru is now up
[ 35.815155] pps pps1: new PPS source ptp3
[ 35.883451] TI DP83867 b232400.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b232400.mdio:00, irq=POLL)
[ 35.883778] net eth3: started
[ 36.168299] remoteproc remoteproc16: powering up b238000.pru
[ 36.168568] remoteproc remoteproc16: Booting fw image ti-pruss/am65x-sr2-pru1-prueth-fw.elf, size 36588
[ 36.168600] remoteproc remoteproc16: unsupported resource 5
[ 36.168629] remoteproc remoteproc16: remote processor b238000.pru is now up
[ 36.168664] remoteproc remoteproc17: powering up b206000.rtu
[ 36.168818] remoteproc remoteproc17: Booting fw image ti-pruss/am65x-sr2-rtu1-prueth-fw.elf, size 29184
[ 36.168851] remoteproc remoteproc17: remote processor b206000.rtu is now up
[ 36.168873] remoteproc remoteproc18: powering up b20c000.txpru
[ 36.169013] remoteproc remoteproc18: Booting fw image ti-pruss/am65x-sr2-txpru1-prueth-fw.elf, size 34552
[ 36.169050] remoteproc remoteproc18: remote processor b20c000.txpru is now up
[ 36.193080] TI DP83867 b232400.mdio:03: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b232400.mdio:03, irq=POLL)
[ 36.193405] net eth4: started
[ 36.408096] remoteproc remoteproc7: powering up b134000.pru
[ 36.408377] remoteproc remoteproc7: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 36316
[ 36.408414] remoteproc remoteproc7: unsupported resource 5
[ 36.408446] remoteproc remoteproc7: remote processor b134000.pru is now up
[ 36.408484] remoteproc remoteproc8: powering up b104000.rtu
[ 36.408653] remoteproc remoteproc8: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 29944
[ 36.408701] remoteproc remoteproc8: remote processor b104000.rtu is now up
[ 36.408729] remoteproc remoteproc9: powering up b10a000.txpru
[ 36.408886] remoteproc remoteproc9: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 35916
[ 36.408934] remoteproc remoteproc9: remote processor b10a000.txpru is now up
[ 36.410451] pps pps2: new PPS source ptp4
[ 36.421154] TI DP83867 b132400.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b132400.mdio:00, irq=POLL)
[ 36.421477] net eth5: started
[ 36.476127] remoteproc remoteproc10: powering up b138000.pru
[ 36.476349] remoteproc remoteproc10: Booting fw image ti-pruss/am65x-sr2-pru1-prueth-fw.elf, size 36588
[ 36.476379] remoteproc remoteproc10: unsupported resource 5
[ 36.476409] remoteproc remoteproc10: remote processor b138000.pru is now up
[ 36.476442] remoteproc remoteproc11: powering up b106000.rtu
[ 36.476565] remoteproc remoteproc11: Booting fw image ti-pruss/am65x-sr2-rtu1-prueth-fw.elf, size 29184
[ 36.476598] remoteproc remoteproc11: remote processor b106000.rtu is now up
[ 36.476621] remoteproc remoteproc12: powering up b10c000.txpru
[ 36.476738] remoteproc remoteproc12: Booting fw image ti-pruss/am65x-sr2-txpru1-prueth-fw.elf, size 34552
[ 36.476774] remoteproc remoteproc12: remote processor b10c000.txpru is now up
[ 36.481014] TI DP83867 b132400.mdio:03: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b132400.mdio:03, irq=POLL)
[ 36.481323] net eth6: started
[ 143.062853] Initializing XFRM netlink socket
[ 145.363230] process 'docker/tmp/qemu-check548914541/check' started with executable stack
Last login: Tue Aug 24 07:21:38 UTC 2021
root@am65xx-evm:~# phc2sys -s CLOCK_REALTIME -c /dev/ptp4 -O 0 -m
phc2sys[168.791]: /dev/ptp4 sys offset -585375821865600332 s0 freq +0
phc2sys[169.793]: /dev/ptp4 sys offset 5134053190471960488 s1 freq +10000000
phc2sys[170.793]: /dev/ptp4 sys offset 991607160 s2 freq +10000000
phc2sys[171.794]: /dev/ptp4 sys offset 1982135984 s2 freq +10000000
phc2sys[172.794]: /dev/ptp4 sys offset 2972654704 s2 freq +10000000
phc2sys[173.795]: /dev/ptp4 sys offset 3963195100 s2 freq +10000000
phc2sys[174.795]: /dev/ptp4 sys offset 4953715268 s2 freq +10000000
phc2sys[175.796]: /dev/ptp4 sys offset 5944279232 s2 freq +10000000
phc2sys[176.796]: /dev/ptp4 sys offset 6934800712 s2 freq +10000000
phc2sys[177.797]: /dev/ptp4 sys offset 7925320496 s2 freq +10000000
phc2sys[178.797]: /dev/ptp4 sys offset 8915830100 s2 freq +10000000
phc2sys[179.798]: /dev/ptp4 sys offset 9906343216 s2 freq +10000000
^Cphc2sys[179.842]: /dev/ptp4 sys offset -3504263346148290648 s2 freq -10000000 delay 0
root@am65xx-evm:~# phc2sys -c CLOCK_REALTIME -s /dev/ptp4 -O 0 -m
phc2sys[190.050]: CLOCK_REALTIME phc offset 5719428991085852536 s0 freq +0
phc2sys[191.050]: CLOCK_REALTIME phc offset -21270228068 s1 freq -100000000
phc2sys[192.088]: CLOCK_REALTIME phc offset -22222635708 s2 freq -100000000
phc2sys[193.103]: CLOCK_REALTIME phc offset -23155027412 s2 freq -100000000
phc2sys[194.111]: CLOCK_REALTIME phc offset -24080160312 s2 freq -100000000
phc2sys[195.115]: CLOCK_REALTIME phc offset -25002611112 s2 freq -100000000
phc2sys[196.117]: CLOCK_REALTIME phc offset -25922623756 s2 freq -100000000
phc2sys[197.142]: CLOCK_REALTIME phc offset -26863701616 s2 freq -100000000
phc2sys[198.165]: CLOCK_REALTIME phc offset -27802809124 s2 freq -100000000
phc2sys[199.174]: CLOCK_REALTIME phc offset -28729045260 s2 freq -100000000
phc2sys[200.182]: CLOCK_REALTIME phc offset -29655055708 s2 freq -100000000
^Cphc2sys[200.560]: clockcheck: clock jumped forward or running faster than expected!
phc2sys[200.560]: CLOCK_REALTIME phc offset 3504263326096007556 s0 freq -100000000 delay 0
root@am65xx-evm:~#
Steps to reproduce:
1) Download and istall 8.0 SDK: https://software-dl.ti.com/processor-sdk-linux-rt/esd/AM65X/08_00_00_02/exports/ti-processor-sdk-linux-rt-am65xx-evm-08_00_00_02-Linux-x86-Install.bin
2) Create SD card (assuming /dev/sdd is your SD card device):
cd ti-processor-sdk-linux-rt-am65xx-evm-08_00_00_02/bin/
sudo ./mksdboot.sh --sdk .. --device /dev/sdd
3) Connect serial cable and boot the IDK
4) Hit enter and Login as root, no password
5) Run "phc2sys -s CLOCK_REALTIME -c /dev/ptp4 -O 0 -m" or "phc2sys -c CLOCK_REALTIME -s /dev/ptp4 -O 0 -m"
