Other Parts Discussed in Thread: TLK110, CDCE913
What are the TI recommended ethernet PHY solution for Ethercat using AM335x. I saw TLK110 but it is out of stock. What are the basic requirements the PHY chip needs to meet for EtherCAT compatibility.
Hi Jagbir,
There are several TI PHYs that are suitable for EtherCAT (DP83848, DP83849, DP83822, ...), although we generally recommend using DP83826 with a processor that is MII capable for reduced latency.
The above appnote has more information about selecting PHYs for EtherCAT.
Thank you,
Evan
Thanks Evan. I am using DP83826ERHBR. In some reference design for example TMDXICE3359(ICE development board), the XI clock input pins of both the PHYs are driven from the clock synthesizer(CDCE913) . Can't we use a local crystal for each PHY for an EtherCAT functionality.
Hi Jagbir,
Please note the following requirement for the clock source and PHY => ESC connection:
https://www.ti.com/lit/an/snla344b/snla344b.pdf
Thank you,
Evan
Thanks Evan.
Your input was really helpful. What is the purpose of using a bus switch(SN74CBTLV3257RGY) along with a muxing /ORing logic (SN74LVC1G32DCK) when interfacing a PHY with AM335x as an ESC(for example in the TI reference design TMDXICE3359) .
Hi Jagbir,
Please try to consolidate similar queries to one thread. I have addressed this in the below thread:
Thank you,
Evan
