Part Number: SK-AM62A-LP
compiler example mcan loopback interrupt has no am62a-mcu-r5f0_0-fw
boot mode:tf card
on mcu_plus_sdk_am62ax_08_06_00_18\examples\drivers\mcan\mcan_loopback_interrupt\am62ax-sk\mcu-r5fss0-0_freertos\ti-arm-clang directory
fix makefile on the same directory
--- a/mcu_plus_sdk_am62ax_08_06_00_18/examples/drivers/mcan/mcan_loopback_interrupt/am62ax-sk/mcu-r5fss0-0_freertos/ti-arm-clang/makefile
+++ b/mcu_plus_sdk_am62ax_08_06_00_18/examples/drivers/mcan/mcan_loopback_interrupt/am62ax-sk/mcu-r5fss0-0_freertos/ti-arm-clang/makefile
@@ -172,6 +172,8 @@ $(OUTNAME): syscfg $(SYSCFG_GEN_FILES) $(OBJS) $(LNK_FILES) $(LIBS_NAME)
@echo .
@echo Linking: am62ax:mcu-r5fss0-0:freertos:ti-arm-clang $@ ...
$(LNK) $(LNKOPTFLAGS) $(LFLAGS) $(LIBS_PATH) -Wl,-m=$(basename $@).map -o $@ $(addprefix $(OBJDIR), $(OBJS)) $(LIBS) $(LNK_FILES)
+ $(RM) am62a-mcu-r5f0_0-fw
+ $(STRIP) -p $@ -o=am62a-mcu-r5f0_0-fw
@echo Linking: am62ax:mcu-r5fss0-0:freertos:ti-arm-clang $@ Done !!!
@echo .
@@ -179,6 +181,7 @@ clean:
@echo Cleaning: am62ax:mcu-r5fss0-0:freertos:ti-arm-clang $(OUTNAME) ...
$(RMDIR) $(OBJDIR)
$(RM) $(OUTNAME)
$(RM) $(BOOTIMAGE_NAME)
$(RM) $(BOOTIMAGE_NAME_XIP)
$(RM) $(BOOTIMAGE_NAME_SIGNED)
@@ -191,6 +194,7 @@ clean:
scrub:
@echo Scrubing: am62ax:mcu-r5fss0-0:freertos:ti-arm-clang mcan_loopback_interrupt ...
$(RMDIR) obj
ifeq ($(OS),Windows_NT)
$(RM) \*.out
$(RM) \*.map
but push the bin instead of /lib/firmware/pdk-ipc/am62a-mcu-r5f0_0-fw
power on board, It has no print,I can't boot
I put the binary below ,It can boot
\mcu_plus_sdk_am62ax_08_06_00_18\examples\drivers\ipc\ipc_rpmsg_echo_linux\am62ax-sk\mcu-r5fss0-0_freertos\ti-arm-clang
why mcu_plus_sdk_am62ax_08_06_00_18\examples\drivers\mcan\mcan_loopback_interrupt\am62ax-sk\mcu-r5fss0-0_freertos\ti-arm-clang\am62a-mcu-r5f0_0-fw can't boot up
I see doc on mcu_plus_sdk_am62ax_08_06_00_18/docs/api_guide_am62ax/EXAMPLES_DRIVERS_MCAN_LOOPBACK_INTERRUPT.html
It's can boot
what's wrong with my operations?
