SK-AM62A-LP: ISP Tuning DCC Tool Required
Part Number: SK-AM62A-LP
Dear ti expert
         Can you please provide me SK-AM62A-LP DCC Tuning Tools of Windows or ubuntu  version release?
I'm ready to debug the ISP,But lack of tools
I search e2e about dcc turning tools,find below link and request
TDA4VM: TDA4VM ISP DCC Tuning Tool - Processors forum - Processors - TI E2E support forums
request link
https://www.ti.com/licreg/docs/swlicexportcontrol.tsp?form_id=276074&prod_no=ADAS-SW-IMAGING&ref_url=adas
but get nothing
  • Hello Daiwei,
    Can you please ask TI's local FAE contact supporting you for this? You can ask them to contact me offline.
    Jianzhong
  • I ask for local fae, re applying, but there is still no news, may it take one or two days?
  • Hello Daiwei,
    Please ask your TI FAE to contact me. I will then provide you the access after NDA confirmation with the FAE.
    Jianzhong
  • ok.I have the tools,but I do not get raw data from target(am62ax-lp-evm board)
    PROCESSOR-SDK-AM68A: [AM68A] How to capture the Raw image from TI EVK and DCC Tool - Sensors forum - Sensors - TI E2E support forums
    my sdk version is sdk806.wic.xz
    1. Navigate to /opt/edgeai-tiovx-modules/
    2. In the CMakeLists.txt file, modify (ENABLE_DCC_TOOL  "Enable DCC Tuning Tool Support" OFF -> ON)
    3. mkdir build
    4. cd build
    5. cmake ..
    6. make -j2
    7. make install
    reboot machine and turn on the imx219 camera
    systemctl stop weston.service
    media-ctl -V '"imx219 4-0010":0 [fmt:SRGGB10_1X10/1920x1080 field:none]'
     gst-launch-1.0 v4l2src device=/dev/video2 io-mode=dmabuf-import ! \
    video/x-bayer, width=1920, height=1080, framerate=30/1, format=rggb10 ! \
    tiovxisp sink_0::device=/dev/v4l-subdev2 \
    sensor-name="SENSOR_SONY_IMX219_RPI" \
    dcc-isp-file=/opt/imaging/imx219/dcc_viss_10b.bin \
    sink_0::dcc-2a-file=/opt/imaging/imx219/dcc_2a_10b.bin format-msb=9 ! \
    video/x-raw, format=NV12, width=1920, height=1080, framerate=30/1 ! \
    kmssink driver-name=tidss sync=false
    the ethernet net link RJ45 is direct connection to the pc
    input ip of machine that can ping with each other
    and click save raw or yuv form camera,then the tools print
    Error in capturing the RAW image
  • Hello Daiwei,
    Were you running streaming while trying to capture raw image? You'll need to run streaming in order to do live tuning.
    Jianzhong
  • We have a capture action above
  • Hi Daiwei,
    Are you using SDK 8.6? Live tuning wasn't working on 8.6. Can you try the latest (9.1) instead?
    Jianzhong
  • I download image form the link,but I find this version has problem that camera can't work,I put the dtb releative img ,it can't work
    https://www.ti.com.cn/tool/cn/download/PROCESSOR-SDK-LINUX-AM62A/09.01.00.07
  • Hi Daiwei,
    Would you mind sharing your dmesg and uEnv.txt?
    Thank you.
    Jianzhong
  • BOOT/uEnv.txt
    # This uEnv.txt file can contain additional environment settings that you
    # want to set in U-Boot at boot time.  This can be simple variables such
    # as the serverip or custom variables.  The format of this file is:
    #    variable=value
    # NOTE: This file will be evaluated after the bootcmd is run and the
    #       bootcmd must be set to load this file if it exists (this is the
    #       default on all newer U-Boot images.  This also means that some
    #       variables such as bootdelay cannot be changed by this file since
    #       it is not evaluated until the bootcmd is run.
    # Setting the right U-Boot environment variables
    name_overlays=
    root@am62axx-evm:/opt/edgeai-gst-apps# dmesg -c
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.1.46-g247b2535b2 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Dec  6 17:54:04 UTC 2023
    [    0.000000] Machine model: Texas Instruments AM62A7 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, size 576 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000099800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c7x-dma-memory@99800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000099900000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node c7x-memory@99900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node edgeai-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node edgeai_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ae000000, size 288 MiB
    [    0.000000] OF: reserved mem: initialized node edgeai-core-heap-memory@ae000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x00000000997fffff]
    [    0.000000]   node   0: [mem 0x0000000099800000-0x000000009b7fefff]
    [    0.000000]   node   0: [mem 0x000000009b800000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
    [    0.000000]   node   0: [mem 0x000000009e780000-0x00000000a2ffffff]
    [    0.000000]   node   0: [mem 0x00000000a3000000-0x00000000adffffff]
    [    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000bfffffff]
    [    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 19 pages/cpu s37992 r8192 d31640 u77824
    [    0.000000] pcpu-alloc: s37992 r8192 d31640 u77824 alloc=19*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032191
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=83c21bb6-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [    0.000000] Memory: 2807964K/4194300K available (12288K kernel code, 1266K rwdata, 4020K rodata, 2112K init, 438K bss, 796512K reserved, 589824K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880040000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008500] Console: colour dummy device 80x25
    [    0.013085] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023767] pid_max: default: 32768 minimum: 301
    [    0.028535] LSM: Security Framework initializing
    [    0.033358] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040938] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.050405] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.057840] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.064130] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.071524] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.077894] rcu: Hierarchical SRCU implementation.
    [    0.082800] rcu:     Max phase no-delay instances is 1000.
    [    0.088358] Platform MSI: msi-controller@1820000 domain created
    [    0.094616] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.104020] EFI services will not be available.
    [    0.108879] smp: Bringing up secondary CPUs ...
    [    0.114071] Detected VIPT I-cache on CPU1
    [    0.114161] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.114177] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
    [    0.114219] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.114833] Detected VIPT I-cache on CPU2
    [    0.114900] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.114914] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
    [    0.114943] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.115500] Detected VIPT I-cache on CPU3
    [    0.115572] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.115585] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
    [    0.115612] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.115676] smp: Brought up 1 node, 4 CPUs
    [    0.195393] SMP: Total of 4 processors activated.
    [    0.200205] CPU features: detected: 32-bit EL0 Support
    [    0.205474] CPU features: detected: CRC32 instructions
    [    0.210779] CPU: All CPU(s) started at EL2
    [    0.214977] alternatives: applying system-wide alternatives
    [    0.222102] devtmpfs: initialized
    [    0.233620] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.243610] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.264143] pinctrl core: initialized pinctrl subsystem
    [    0.270021] DMI not present or invalid.
    [    0.274495] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.281434] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.288877] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.296959] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.305120] audit: initializing netlink subsys (disabled)
    [    0.310766] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
    [    0.311149] thermal_sys: Registered thermal governor 'step_wise'
    [    0.318695] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.324873] cpuidle: using governor menu
    [    0.335701] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.342717] ASID allocator initialised with 65536 entries
    [    0.359253] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
    [    0.370551] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
    [    0.380009] KASLR disabled due to lack of seed
    [    0.391047] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.398012] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.404423] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.411363] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.417771] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.424710] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.431119] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.438058] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.445677] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected
    [    0.455775] iommu: Default domain type: Translated
    [    0.460784] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.467435] SCSI subsystem initialized
    [    0.471395] libata version 3.00 loaded.
    [    0.471552] usbcore: registered new interface driver usbfs
    [    0.477197] usbcore: registered new interface driver hub
    [    0.482654] usbcore: registered new device driver usb
    [    0.488213] pps_core: LinuxPPS API ver. 1 registered
    [    0.493292] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.502640] PTP clock support registered
    [    0.506775] EDAC MC: Ver: 3.0.0
    [    0.510769] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    0.517596] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    0.524400] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
    [    0.531127] omap-mailbox 29030000.mailbox: no available mbox devices found
    [    0.538437] FPGA manager framework
    [    0.541982] Advanced Linux Sound Architecture Driver Initialized.
    [    0.549051] clocksource: Switched to clocksource arch_sys_counter
    [    0.555496] VFS: Disk quotas dquot_6.6.0
    [    0.559547] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.572323] Carveout Heap: Exported 176 MiB at 0x00000000a3000000
    [    0.578669] NET: Registered PF_INET protocol family
    [    0.583849] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.594293] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.603108] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.611045] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.619350] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
    [    0.627730] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.634589] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.641548] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.649074] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.655234] RPC: Registered named UNIX socket transport module.
    [    0.661310] RPC: Registered udp transport module.
    [    0.666119] RPC: Registered tcp transport module.
    [    0.670927] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.677517] NET: Registered PF_XDP protocol family
    [    0.682426] PCI: CLS 0 bytes, default 64
    [    0.687057] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.696926] Initialise system trusted keyrings
    [    0.701681] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.712585] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.719099] NFS: Registering the id_resolver key type
    [    0.724310] Key type id_resolver registered
    [    0.728588] Key type id_legacy registered
    [    0.732740] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.739595] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.782380] Key type asymmetric registered
    [    0.786573] Asymmetric key parser 'x509' registered
    [    0.791600] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.799286] io scheduler mq-deadline registered
    [    0.803925] io scheduler kyber registered
    [    0.811020] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.817460] pinctrl-single f4000.pinctrl: 151 pins, size 604
    [    0.824264] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.836224] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.851426] loop: module loaded
    [    0.855803] megasas: 07.719.03.00-rc1
    [    0.862445] tun: Universal TUN/TAP device driver, 1.6
    [    0.868323] thunder_xcv, ver 1.0
    [    0.871664] thunder_bgx, ver 1.0
    [    0.874995] nicpf, ver 1.0
    [    0.877919] e1000: Intel(R) PRO/1000 Network Driver
    [    0.882911] e1000: Copyright (c) 1999-2006 Intel Corporation.
    [    0.888821] e1000e: Intel(R) PRO/1000 Network Driver
    [    0.893896] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    0.899980] igb: Intel(R) Gigabit Ethernet Network Driver
    [    0.905499] igb: Copyright (c) 2007-2014 Intel Corporation.
    [    0.911219] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.917627] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.923790] sky2: driver version 1.30
    [    0.928217] VFIO - User Level meta-driver version: 0.3
    [    0.934145] usbcore: registered new interface driver usb-storage
    [    0.940822] i2c_dev: i2c /dev entries driver
    [    0.946549] sdhci: Secure Digital Host Controller Interface driver
    [    0.952896] sdhci: Copyright(c) Pierre Ossman
    [    0.957559] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.964059] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.970389] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.977332] usbcore: registered new interface driver usbhid
    [    0.983034] usbhid: USB HID core driver
    [    0.987756] optee: probing for conduit method.
    [    0.992333] optee: revision 4.0 (2a5b1d12)
    [    0.992597] optee: dynamic shared memory is enabled
    [    1.002132] optee: initialized driver
    [    1.007324] Initializing XFRM netlink socket
    [    1.011734] NET: Registered PF_PACKET protocol family
    [    1.016966] Key type dns_resolver registered
    [    1.021697] registered taskstats version 1
    [    1.025913] Loading compiled-in X.509 certificates
    [    1.038909] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
    [    1.079131] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.086180] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    1.093080] pca953x 1-0023: using AI
    [    1.119610] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.126382] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.132312] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    1.140633] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.149838] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.158837] ti-sci-inta 4e0a0000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    1.168572] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.176616] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.187489] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.197332] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.206639] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    1.213131] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    1.222328] printk: console [ttyS2] disabled
    [    1.226762] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 253, base_baud = 3000000) is a 8250
    [    1.235640] printk: console [ttyS2] enabled
    [    1.244101] printk: bootconsole [ns16550a0] disabled
    [    1.256285] spi-nand spi0.0: Winbond SPI NAND was found.
    [    1.261622] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
    [    1.269986] 7 fixed-partitions partitions found on MTD device spi0.0
    [    1.276341] Creating 7 MTD partitions on "spi0.0":
    [    1.281127] 0x000000000000-0x000000080000 : "ospi_nand.tiboot3"
    [    1.288391] 0x000000080000-0x000000280000 : "ospi_nand.tispl"
    [    1.295968] 0x000000280000-0x000000680000 : "ospi_nand.u-boot"
    [    1.304419] 0x000000680000-0x0000006c0000 : "ospi_nand.env"
    [    1.311089] 0x0000006c0000-0x000000700000 : "ospi_nand.env.backup"
    [    1.318352] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
    [    1.362945] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
    [    1.409089] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.418155] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.426289] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    1.439062] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.446190] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.452558] pps pps0: new PPS source ptp0
    [    1.456819] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.467094] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.475461] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
    [    1.487829] mmc0: CQHCI version 5.10
    [    1.532699] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.654769] mmc0: Command Queue Engine enabled
    [    1.659254] mmc0: new HS200 MMC card at address 0001
    [    1.665126] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    1.670971]  mmcblk0: p1 p2
    [    1.674320] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
    [    1.680204] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
    [    1.686008] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0)
    [    1.876775] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
    [    1.882769] tps6594-rtc tps6594-rtc.4.auto: hctosys: unable to read the hardware clock
    [    1.890973] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.897737] pca953x 1-0022: using AI
    [    1.907651] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.908280] mmc1: CQHCI version 5.10
    [    1.916065] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.925958] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.939811] ALSA device list:
    [    1.942835]   No soundcards found.
    [    1.959795] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.967476] Waiting for root device PARTUUID=83c21bb6-02...
    [    2.022703] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
    [    2.037113] mmcblk1: mmc1:aaaa SD32G 29.7 GiB
    [    2.043676]  mmcblk1: p1 p2
    [    2.145746] EXT4-fs (mmcblk1p2): recovery complete
    [    2.151413] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    2.160007] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    2.166688] devtmpfs: mounted
    [    2.170593] Freeing unused kernel memory: 2112K
    [    2.175362] Run /sbin/init as init process
    [    2.179500]   with arguments:
    [    2.179504]     /sbin/init
    [    2.179508]   with environment:
    [    2.179511]     HOME=/
    [    2.179515]     TERM=linux
    [    2.325962] systemd[1]: System time before build time, advancing clock.
    [    2.383045] NET: Registered PF_INET6 protocol family
    [    2.389642] Segment Routing with IPv6
    [    2.393467] In-situ OAM (IOAM) with IPv6
    [    2.427897] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    2.459961] systemd[1]: Detected architecture arm64.
    [    2.546368] systemd[1]: Hostname set to <am62axx-evm>.
    [    2.554448] systemd[1]: Initializing machine ID from random generator.
    [    2.661851] systemd-sysv-generator[158]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.690797] systemd-sysv-generator[158]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.716648] systemd-sysv-generator[158]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.741974] systemd-sysv-generator[158]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    3.060371] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.128045] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.205857] systemd[1]: Queued start job for default target Graphical Interface.
    [    3.279359] systemd[1]: Created slice Slice /system/getty.
    [    3.304277] systemd[1]: Created slice Slice /system/modprobe.
    [    3.328326] systemd[1]: Created slice Slice /system/serial-getty.
    [    3.357326] systemd[1]: Created slice User and Session Slice.
    [    3.377612] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.401581] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.425812] systemd[1]: Reached target Path Units.
    [    3.441455] systemd[1]: Reached target Remote File Systems.
    [    3.461437] systemd[1]: Reached target Slice Units.
    [    3.477443] systemd[1]: Reached target Swaps.
    [    3.555078] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    3.577570] systemd[1]: Reached target RPC Port Mapper.
    [    3.614146] systemd[1]: Listening on Process Core Dump Socket.
    [    3.638041] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    3.663023] systemd[1]: Listening on Journal Audit Socket.
    [    3.687744] systemd[1]: Listening on Journal Socket (/dev/log).
    [    3.711846] systemd[1]: Listening on Journal Socket.
    [    3.731118] systemd[1]: Listening on Network Service Netlink Socket.
    [    3.756327] systemd[1]: Listening on udev Control Socket.
    [    3.779289] systemd[1]: Listening on udev Kernel Socket.
    [    3.803646] systemd[1]: Listening on User Database Manager Socket.
    [    3.865731] systemd[1]: Mounting Huge Pages File System...
    [    3.900154] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.932094] systemd[1]: Mounting Kernel Debug File System...
    [    3.950390] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    4.001783] systemd[1]: Mounting Temporary Directory /tmp...
    [    4.030538] systemd[1]: Starting Create List of Static Device Nodes...
    [    4.060492] systemd[1]: Starting Load Kernel Module configfs...
    [    4.084486] systemd[1]: Starting Load Kernel Module drm...
    [    4.122079] systemd[1]: Starting Load Kernel Module fuse...
    [    4.138610] fuse: init (API version 7.37)
    [    4.155590] systemd[1]: Starting Start psplash boot splash screen...
    [    4.184502] systemd[1]: Starting RPC Bind...
    [    4.201551] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    4.238002] systemd[1]: Starting Journal Service...
    [    4.262496] systemd[1]: Starting Load Kernel Modules...
    [    4.282683] cryptodev: loading out-of-tree module taints kernel.
    [    4.282969] systemd[1]: Starting Generate network units from Kernel command line...
    [    4.297353] cryptodev: driver 1.12 loaded.
    [    4.350203] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.381210] systemd[1]: Starting Coldplug All udev Devices...
    [    4.381270] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    4.418797] systemd[1]: Started RPC Bind.
    [    4.441783] systemd[1]: Started Journal Service.
    [    4.831003] systemd-journald[174]: Received client request to flush runtime journal.
    [    5.165204] audit: type=1334 audit(1651167747.836:2): prog-id=5 op=LOAD
    [    5.171999] audit: type=1334 audit(1651167747.844:3): prog-id=6 op=LOAD
    [    5.800384] random: crng init done
    [    5.892381] mc: Linux media interface: v0.10
    [    5.937744] videodev: Linux video capture interface: v2.00
    [    6.023537] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@99800000
    [    6.032766] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode
    [    6.039852] remoteproc remoteproc0: 7e000000.dsp is available
    [    6.046649] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found
    [    6.053589] vdec 30210000.video-codec: failed to get irq resource, falling back to polling
    [    6.065496] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
    [    6.068923] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    6.084068] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    6.091444] platform 79000000.r5f: configured R5F for remoteproc mode
    [    6.101681] platform 79000000.r5f: assigned reserved memory node r5f-dma-memory@9b800000
    [    6.102141] i2c i2c-1: Added multiplexed i2c bus 3
    [    6.134166] remoteproc remoteproc1: 79000000.r5f is available
    [    6.148728] remoteproc remoteproc0: powering up 7e000000.dsp
    [    6.154764] remoteproc remoteproc0: Booting fw image am62a-c71_0-fw, size 11046992
    [    6.170747] remoteproc remoteproc1: powering up 79000000.r5f
    [    6.176553] remoteproc remoteproc1: Booting fw image am62a-mcu-r5f0_0-fw, size 52148
    [    6.197123] k3-dsp-rproc 7e000000.dsp: booting DSP core using boot addr = 0x99a00000
    [    6.197438] rtc-ti-k3 2b1f0000.rtc: Clock rate 32552 is not 32768! Could misbehave!
    [    6.211907] rproc-virtio rproc-virtio.6.auto: assigned reserved memory node c7x-dma-memory@99800000
    [    6.216275] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [    6.222553] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.234737] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    6.242229] rproc-virtio rproc-virtio.6.auto: registered virtio0 (type 7)
    [    6.242683] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    6.249095] rproc-virtio rproc-virtio.7.auto: assigned reserved memory node r5f-dma-memory@9b800000
    [    6.249169] remoteproc remoteproc0: remote processor 7e000000.dsp is now up
    [    6.261190] platform 78000000.r5f: configured R5F for IPC-only mode
    [    6.283236] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.291931] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.292037] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.292281] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
    [    6.295838] remoteproc remoteproc2: 78000000.r5f is available
    [    6.295929] remoteproc remoteproc2: attaching to 78000000.r5f
    [    6.296330] platform 78000000.r5f: R5F core initialized in IPC-only mode
    [    6.296345] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.296760] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    6.296783] rproc-virtio rproc-virtio.9.auto: registered virtio2 (type 7)
    [    6.296790] remoteproc remoteproc2: remote processor 78000000.r5f is now attached
    [    6.297545] rproc-virtio rproc-virtio.7.auto: registered virtio1 (type 7)
    [    6.305190] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    6.310122] remoteproc remoteproc1: remote processor 79000000.r5f is now up
    [    6.378227] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [    6.385697] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    6.395885] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [    6.403261] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.410576] Console: switching to colour frame buffer device 240x67
    [    6.456619] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
    [    6.459760] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.563183] e5010 fd20000.e5010: Device registered as /dev/video2
    [    6.752257] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [    6.765591] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [    6.766488] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
    [    6.778422] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [    6.820058] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [    6.825454] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    [    6.840567] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [    7.398210] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [    7.433447] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [    7.435386] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [    7.483316] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [    7.504399] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [    7.537399] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [    7.579493] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [    7.601645] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [    7.655024] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
    [    7.668259] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 1
    [    7.679826] xhci-hcd xhci-hcd.10.auto: USB3 root hub has no ports
    [    7.690014] xhci-hcd xhci-hcd.10.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
    [    7.700965] xhci-hcd xhci-hcd.10.auto: irq 538, io mem 0x31100000
    [    7.701784] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [    7.712953] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [    7.737464] hub 1-0:1.0: USB hub found
    [    7.741503] hub 1-0:1.0: 1 port detected
    [    7.754831] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
    [    7.782617] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    [    7.836885] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [    8.277665] audit: type=1334 audit(1651167750.952:4): prog-id=7 op=LOAD
    [    8.286909] audit: type=1334 audit(1651167750.956:5): prog-id=8 op=LOAD
    [    8.392719] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [    8.428526] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
    [    8.444479] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [    8.462962] Bluetooth: Core ver 2.22
    [    8.468481] NET: Registered PF_BLUETOOTH protocol family
    [    8.477943] Bluetooth: HCI device and connection manager initialized
    [    8.486898] Bluetooth: HCI socket layer initialized
    [    8.492084] Bluetooth: L2CAP socket layer initialized
    [    8.497305] Bluetooth: SCO socket layer initialized
    [    8.722261] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    8.745475] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    8.902443] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    8.911869] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    9.199514] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [    9.213983] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [    9.243830] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [    9.264555] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [    9.277783] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    [    9.301316] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    9.316029] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [    9.332517] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
    [    9.344006] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [    9.389087] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [    9.467573] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [    9.516369] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [    9.561882] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    [    9.775508] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [    9.814267] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
    [    9.891786] audit: type=1334 audit(1651167752.564:6): prog-id=9 op=LOAD
    [    9.900909] audit: type=1334 audit(1651167752.572:7): prog-id=10 op=LOAD
    [    9.903120] EXT4-fs (mmcblk1p2): resizing filesystem from 2506931 to 7758720 blocks
    [   10.362895] audit: type=1006 audit(1651167753.036:8): pid=781 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [   10.375533] audit: type=1300 audit(1651167753.036:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffff6d26b78 a2=4 a3=ffff83d51020 items=0 ppid=1 pid=781 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [   10.402081] audit: type=1327 audit(1651167753.036:8): proctitle="(systemd)"
    [   11.959704] EXT4-fs (mmcblk1p2): resized filesystem to 7758720
    [   12.369205] audit: type=1006 audit(1651167755.044:9): pid=767 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
    [   12.382208] audit: type=1300 audit(1651167755.044:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffff6d26b78 a2=4 a3=ffff83d51020 items=0 ppid=1 pid=767 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
    [   12.408576] audit: type=1327 audit(1651167755.044:9): proctitle="(weston)"
    [   17.133318] audit: type=1006 audit(1651167759.808:10): pid=1303 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
    [   17.151875] audit: type=1300 audit(1651167759.808:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff6d26b78 a2=1 a3=ffff83d51020 items=0 ppid=1 pid=1303 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [   17.178355] audit: type=1327 audit(1651167759.808:10): proctitle="(systemd)"
    [   17.185476] audit: type=1334 audit(1651167759.840:11): prog-id=11 op=LOAD
    [   17.192364] audit: type=1300 audit(1651167759.840:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffd1432200 a2=78 a3=0 items=0 ppid=1 pid=1303 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
    [   17.218499] audit: type=1327 audit(1651167759.840:11): proctitle="(systemd)"
    [   17.226226] audit: type=1334 audit(1651167759.852:12): prog-id=11 op=UNLOAD
    [   17.233889] audit: type=1334 audit(1651167759.852:13): prog-id=12 op=LOAD
    [   17.241471] audit: type=1300 audit(1651167759.852:13): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffd14322a0 a2=78 a3=0 items=0 ppid=1 pid=1303 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
    [   17.267289] audit: type=1327 audit(1651167759.852:13): proctitle="(systemd)"
  • uEnv.txt
    psdk_setup_file=.psdk_setup
    check_psdk_setup=load mmc 1:1 ${loadaddr} ${psdk_setup_file}
    # Reset to the default environment
    do_psdk_setup=env default -f -a; saveenv
    # If not previously configured, then configure the environment and indicate this by writing a file
    uenvcmd=if run check_psdk_setup; then echo "Already setup."; else run do_psdk_setup; mw.b ${loadaddr} 0 1; fatwrite mmc 1:1 ${loadaddr} .psdk_setup 1; reset; fi
    dorprocboot=0
    name_overlays=k3-am62a7-sk-csi2-imx219.dtbo
    am62axx-evm login: root
    [   20.617148] audit: type=1006 audit(1651167944.692:10): pid=1289 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
    [   20.629721] audit: type=1300 audit(1651167944.692:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffd0e16288 a2=1 a3=ffffb759b020 items=0 ppid=1 pid=1289 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [   20.656422] audit: type=1327 audit(1651167944.692:10): proctitle="(systemd)"
    [   20.663533] audit: type=1334 audit(1651167944.720:11): prog-id=11 op=LOAD
    [   20.670409] audit: type=1300 audit(1651167944.720:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe9e490c0 a2=78 a3=0 items=0 ppid=1 pid=1289 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
    [   20.696125] audit: type=1327 audit(1651167944.720:11): proctitle="(systemd)"
    [   20.703221] audit: type=1334 audit(1651167944.732:12): prog-id=11 op=UNLOAD
    [   20.710226] audit: type=1334 audit(1651167944.732:13): prog-id=12 op=LOAD
    [   20.717074] audit: type=1300 audit(1651167944.732:13): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe9e49160 a2=78 a3=0 items=0 ppid=1 pid=1289 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
    [   20.742740] audit: type=1327 audit(1651167944.732:13): proctitle="(systemd)"
    root@am62axx-evm:/opt/edgeai-gst-apps# media-ctl  -p
    Media controller API version 6.1.46
    Media device information
    driver          j721e-csi2rx
    model           TI-CSI2RX
    serial
    bus info        platform:30102000.ticsi2rx
    hw revision     0x1
    driver version  6.1.46
    Device topology
    - entity 1: 30102000.ticsi2rx (7 pads, 0 link, 0 route)
                type V4L2 subdev subtype Unknown flags 0
            pad0: Sink
            pad1: Source
            pad2: Source
            pad3: Source
            pad4: Source
            pad5: Source
            pad6: Source
    [    0.008498] Console: colour dummy device 80x25
    [    0.023765] pid_max: default: 32768 minimum: 301
    [    0.028531] LSM: Security Framework initializing
    [    0.033354] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040933] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.050389] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.057824] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.064113] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.071508] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.077878] rcu: Hierarchical SRCU implementation.
    [    0.082783] rcu:     Max phase no-delay instances is 1000.
    [    0.088345] Platform MSI: msi-controller@1820000 domain created
    [    0.094595] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.103993] EFI services will not be available.
    [    0.108855] smp: Bringing up secondary CPUs ...
    [    0.114053] Detected VIPT I-cache on CPU1
    [    0.114140] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.114157] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
    [    0.114199] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.114809] Detected VIPT I-cache on CPU2
    [    0.114873] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.114886] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
    [    0.114917] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.115472] Detected VIPT I-cache on CPU3
    [    0.115544] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.115557] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
    [    0.115585] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.115647] smp: Brought up 1 node, 4 CPUs
    [    0.195367] SMP: Total of 4 processors activated.
    [    0.200179] CPU features: detected: 32-bit EL0 Support
    [    0.205448] CPU features: detected: CRC32 instructions
    [    0.210752] CPU: All CPU(s) started at EL2
    [    0.214950] alternatives: applying system-wide alternatives
    [    0.222076] devtmpfs: initialized
    [    0.233590] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.243580] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.264125] pinctrl core: initialized pinctrl subsystem
    [    0.270002] DMI not present or invalid.
    [    0.274469] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.281412] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.288852] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.296934] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.305093] audit: initializing netlink subsys (disabled)
    [    0.310744] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
    [    0.311135] thermal_sys: Registered thermal governor 'step_wise'
    [    0.318672] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.324851] cpuidle: using governor menu
    [    0.335680] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.342697] ASID allocator initialised with 65536 entries
    [    0.359219] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
    [    0.370530] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
    [    0.379995] KASLR disabled due to lack of seed
    [    0.391033] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.397996] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.404407] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.411347] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.417755] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.424695] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.431102] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.438041] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.445732] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected
    [    0.455832] iommu: Default domain type: Translated
    [    0.460846] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.467503] SCSI subsystem initialized
    [    0.471462] libata version 3.00 loaded.
    [    0.471619] usbcore: registered new interface driver usbfs
    [    0.477266] usbcore: registered new interface driver hub
    [    0.482722] usbcore: registered new device driver usb
    [    0.488285] pps_core: LinuxPPS API ver. 1 registered
    [    0.493364] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.502712] PTP clock support registered
    [    0.506845] EDAC MC: Ver: 3.0.0
    [    0.510821] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    0.517647] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    0.524450] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
    [    0.531179] omap-mailbox 29030000.mailbox: no available mbox devices found
    [    0.538487] FPGA manager framework
    [    0.542032] Advanced Linux Sound Architecture Driver Initialized.
    [    0.549103] clocksource: Switched to clocksource arch_sys_counter
    [    0.555547] VFS: Disk quotas dquot_6.6.0
    [    0.559595] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.572382] Carveout Heap: Exported 176 MiB at 0x00000000a3000000
    [    0.578728] NET: Registered PF_INET protocol family
    [    0.583906] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.594339] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.603145] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.611083] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.619391] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
    [    0.627755] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.634618] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.641578] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.649105] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.655262] RPC: Registered named UNIX socket transport module.
    [    0.661336] RPC: Registered udp transport module.
    [    0.666145] RPC: Registered tcp transport module.
    [    0.670953] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.677543] NET: Registered PF_XDP protocol family
    [    0.682452] PCI: CLS 0 bytes, default 64
    [    0.687072] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.696941] Initialise system trusted keyrings
    [    0.701703] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.712598] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.719111] NFS: Registering the id_resolver key type
    [    0.724318] Key type id_resolver registered
    [    0.728596] Key type id_legacy registered
    [    0.732747] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.739603] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.782912] Key type asymmetric registered
    [    0.787106] Asymmetric key parser 'x509' registered
    [    0.792131] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.799831] io scheduler mq-deadline registered
    [    0.804469] io scheduler kyber registered
    [    0.811532] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.817971] pinctrl-single f4000.pinctrl: 151 pins, size 604
    [    0.824811] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.836712] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.851827] loop: module loaded
    [    0.856212] megasas: 07.719.03.00-rc1
    [    0.862831] tun: Universal TUN/TAP device driver, 1.6
    [    0.868707] thunder_xcv, ver 1.0
    [    0.872049] thunder_bgx, ver 1.0
    [    0.875374] nicpf, ver 1.0
    [    0.878305] e1000: Intel(R) PRO/1000 Network Driver
    [    0.883297] e1000: Copyright (c) 1999-2006 Intel Corporation.
    [    0.889206] e1000e: Intel(R) PRO/1000 Network Driver
    [    0.894281] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    0.900365] igb: Intel(R) Gigabit Ethernet Network Driver
    [    0.905884] igb: Copyright (c) 2007-2014 Intel Corporation.
    [    0.911611] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.918019] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.924189] sky2: driver version 1.30
    [    0.928608] VFIO - User Level meta-driver version: 0.3
    [    0.934527] usbcore: registered new interface driver usb-storage
    [    0.941208] i2c_dev: i2c /dev entries driver
    [    0.946930] sdhci: Secure Digital Host Controller Interface driver
    [    0.953282] sdhci: Copyright(c) Pierre Ossman
    [    0.957941] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.964458] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.970782] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.977720] usbcore: registered new interface driver usbhid
    [    0.983421] usbhid: USB HID core driver
    [    0.988175] optee: probing for conduit method.
    [    0.992758] optee: revision 4.0 (2a5b1d12)
    [    0.993013] optee: dynamic shared memory is enabled
    [    1.002549] optee: initialized driver
    [    1.007740] Initializing XFRM netlink socket
    [    1.012153] NET: Registered PF_PACKET protocol family
    [    1.017378] Key type dns_resolver registered
    [    1.022104] registered taskstats version 1
    [    1.026318] Loading compiled-in X.509 certificates
    [    1.039319] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
    [    1.080283] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.087309] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    1.094190] pca953x 1-0023: using AI
    [    1.123678] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.130449] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.136376] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    1.144701] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.153899] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.162891] ti-sci-inta 4e0a0000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    1.172592] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.180653] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.191495] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.201319] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.210639] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    1.217130] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    1.226326] printk: console [ttyS2] disabled
    [    1.230761] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 253, base_baud = 3000000) is a 8250
    [    1.239640] printk: console [ttyS2] enabled
    [    1.248101] printk: bootconsole [ns16550a0] disabled
    [    1.260277] spi-nand spi0.0: Winbond SPI NAND was found.
    [    1.265614] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
    [    1.273962] 7 fixed-partitions partitions found on MTD device spi0.0
    [    1.280318] Creating 7 MTD partitions on "spi0.0":
    [    1.285105] 0x000000000000-0x000000080000 : "ospi_nand.tiboot3"
    [    1.292331] 0x000000080000-0x000000280000 : "ospi_nand.tispl"
    [    1.299899] 0x000000280000-0x000000680000 : "ospi_nand.u-boot"
    [    1.308307] 0x000000680000-0x0000006c0000 : "ospi_nand.env"
    [    1.314972] 0x0000006c0000-0x000000700000 : "ospi_nand.env.backup"
    [    1.322263] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
    [    1.366536] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
    [    1.413141] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.422201] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.430333] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    1.443103] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.450231] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.456566] pps pps0: new PPS source ptp0
    [    1.460860] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.471119] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.479453] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
    [    1.491776] mmc0: CQHCI version 5.10
    [    1.536584] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.649973] mmc0: Command Queue Engine enabled
    [    1.654465] mmc0: new HS200 MMC card at address 0001
    [    1.660125] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    1.666190]  mmcblk0: p1 p2
    [    1.669640] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
    [    1.675757] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
    [    1.681535] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0)
    [    1.932741] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
    [    1.941988] tps6594-rtc tps6594-rtc.4.auto: hctosys: unable to read the hardware clock
    [    1.950972] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.957753] pca953x 1-0022: using AI
    [    1.968265] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.975880] mmc1: CQHCI version 5.10
    [    1.976710] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.986881] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.999945] ALSA device list:
    [    2.002943]   No soundcards found.
    [    2.019766] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.027495] Waiting for root device PARTUUID=83c21bb6-02...
    [    2.094897] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
    [    2.112395] mmcblk1: mmc1:aaaa SD32G 29.7 GiB
    [    2.118987]  mmcblk1: p1 p2
    [    2.163631] EXT4-fs (mmcblk1p2): recovery complete
    [    2.169687] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    2.178302] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    2.185002] devtmpfs: mounted
    [    2.188572] Freeing unused kernel memory: 2112K
    [    2.193233] Run /sbin/init as init process
    [    2.197330]   with arguments:
    [    2.197332]     /sbin/init
    [    2.197336]   with environment:
    [    2.197338]     HOME=/
    [    2.197341]     TERM=linux
    [    2.352697] systemd[1]: System time before build time, advancing clock.
    [    2.399370] NET: Registered PF_INET6 protocol family
    [    2.405857] Segment Routing with IPv6
    [    2.409600] In-situ OAM (IOAM) with IPv6
    [    2.442799] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    2.474609] systemd[1]: Detected architecture arm64.
    [    2.550438] systemd[1]: Hostname set to <am62axx-evm>.
    [    2.833184] systemd-sysv-generator[159]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.858693] systemd-sysv-generator[159]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.884962] systemd-sysv-generator[159]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.910329] systemd-sysv-generator[159]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    3.240650] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.307548] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.384252] systemd[1]: Queued start job for default target Graphical Interface.
    [    3.449229] systemd[1]: Created slice Slice /system/getty.
    [    3.471916] systemd[1]: Created slice Slice /system/modprobe.
    [    3.496104] systemd[1]: Created slice Slice /system/serial-getty.
    [    3.519246] systemd[1]: Created slice User and Session Slice.
    [    3.541631] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.565536] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.589748] systemd[1]: Reached target Path Units.
    [    3.605397] systemd[1]: Reached target Remote File Systems.
    [    3.625306] systemd[1]: Reached target Slice Units.
    [    3.641431] systemd[1]: Reached target Swaps.
    [    3.718820] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    3.741711] systemd[1]: Reached target RPC Port Mapper.
    [    3.778251] systemd[1]: Listening on Process Core Dump Socket.
    [    3.802105] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    3.827070] systemd[1]: Listening on Journal Audit Socket.
    [    3.851829] systemd[1]: Listening on Journal Socket (/dev/log).
    [    3.875950] systemd[1]: Listening on Journal Socket.
    [    3.895197] systemd[1]: Listening on Network Service Netlink Socket.
    [    3.920218] systemd[1]: Listening on udev Control Socket.
    [    3.943221] systemd[1]: Listening on udev Kernel Socket.
    [    3.967572] systemd[1]: Listening on User Database Manager Socket.
    [    4.029756] systemd[1]: Mounting Huge Pages File System...
    [    4.051231] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.105779] systemd[1]: Mounting Kernel Debug File System...
    [    4.122382] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    4.147176] systemd[1]: Mounting Temporary Directory /tmp...
    [    4.176283] systemd[1]: Starting Create List of Static Device Nodes...
    [    4.207067] systemd[1]: Starting Load Kernel Module configfs...
    [    4.230588] systemd[1]: Starting Load Kernel Module drm...
    [    4.274221] systemd[1]: Starting Load Kernel Module fuse...
    [    4.289780] fuse: init (API version 7.37)
    [    4.305791] systemd[1]: Starting Start psplash boot splash screen...
    [    4.341417] systemd[1]: Starting RPC Bind...
    [    4.357609] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    4.379411] systemd[1]: Starting Journal Service...
    [    4.405536] systemd[1]: Starting Load Kernel Modules...
    [    4.422952] cryptodev: loading out-of-tree module taints kernel.
    [    4.426445] systemd[1]: Starting Generate network units from Kernel command line...
    [    4.437459] cryptodev: driver 1.12 loaded.
    [    4.463150] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.482536] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    4.514431] systemd[1]: Starting Coldplug All udev Devices...
    [    4.538780] systemd[1]: Started RPC Bind.
    [    4.553926] systemd[1]: Started Journal Service.
    [    4.959434] systemd-journald[175]: Received client request to flush runtime journal.
    [    5.351949] audit: type=1334 audit(1651167747.996:2): prog-id=5 op=LOAD
    [    5.358745] audit: type=1334 audit(1651167748.004:3): prog-id=6 op=LOAD
    [    5.989411] random: crng init done
    [    6.050864] mc: Linux media interface: v0.10
    [    6.071666] videodev: Linux video capture interface: v2.00
    [    6.109405] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
    [    6.188445] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found
    [    6.196046] vdec 30210000.video-codec: failed to get irq resource, falling back to polling
    [    6.200684] platform 31000000.usb: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    6.226517] platform 79000000.r5f: configured R5F for remoteproc mode
    [    6.234608] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@99800000
    [    6.234776] platform 79000000.r5f: assigned reserved memory node r5f-dma-memory@9b800000
    [    6.243723] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode
    [    6.258620] remoteproc remoteproc0: 79000000.r5f is available
    [    6.258950] remoteproc remoteproc1: 7e000000.dsp is available
    [    6.269600] rtc-ti-k3 2b1f0000.rtc: Clock rate 32552 is not 32768! Could misbehave!
    [    6.269700] remoteproc remoteproc0: powering up 79000000.r5f
    [    6.269716] remoteproc remoteproc0: Booting fw image am62a-mcu-r5f0_0-fw, size 52148
    [    6.296292] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    6.299650] rproc-virtio rproc-virtio.5.auto: assigned reserved memory node r5f-dma-memory@9b800000
    [    6.312468] platform 78000000.r5f: configured R5F for IPC-only mode
    [    6.323523] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
    [    6.324470] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.329716] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.329924] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.330063] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    6.378764] remoteproc remoteproc1: powering up 7e000000.dsp
    [    6.384620] remoteproc remoteproc1: Booting fw image am62a-c71_0-fw, size 11046992
    [    6.404531] rproc-virtio rproc-virtio.5.auto: registered virtio0 (type 7)
    [    6.404546] remoteproc remoteproc2: 78000000.r5f is available
    [    6.404625] remoteproc remoteproc2: attaching to 78000000.r5f
    [    6.412053] remoteproc remoteproc0: remote processor 79000000.r5f is now up
    [    6.423002] k3-dsp-rproc 7e000000.dsp: booting DSP core using boot addr = 0x99a00000
    [    6.427580] platform 78000000.r5f: R5F core initialized in IPC-only mode
    [    6.445088] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.454208] rproc-virtio rproc-virtio.7.auto: assigned reserved memory node c7x-dma-memory@99800000
    [    6.454697] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.463907] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    6.474254] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    6.483746] rproc-virtio rproc-virtio.7.auto: registered virtio2 (type 7)
    [    6.487255] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [    6.495479] remoteproc remoteproc1: remote processor 7e000000.dsp is now up
    [    6.501142] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.515802] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    6.522807] rproc-virtio rproc-virtio.8.auto: registered virtio1 (type 7)
    [    6.528665] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [    6.537406] remoteproc remoteproc2: remote processor 78000000.r5f is now attached
    [    6.552346] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [    6.652007] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [    6.656313] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [    6.658900] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [    6.666930] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [    6.668225] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
    [    6.674660] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [    6.676490] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    6.676666] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    6.681326] i2c i2c-1: Added multiplexed i2c bus 3
    [    6.683233] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [    6.694263] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    [    6.761266] e5010 fd20000.e5010: Device registered as /dev/video2
    [    6.805594] Console: switching to colour frame buffer device 240x67
    [    6.849232] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
    [    7.190953] audit: type=1334 audit(1651167931.268:4): prog-id=7 op=LOAD
    [    7.203050] audit: type=1334 audit(1651167931.280:5): prog-id=8 op=LOAD
    [    7.350365] Bluetooth: Core ver 2.22
    [    7.354144] NET: Registered PF_BLUETOOTH protocol family
    [    7.361250] Bluetooth: HCI device and connection manager initialized
    [    7.367791] Bluetooth: HCI socket layer initialized
    [    7.372753] Bluetooth: L2CAP socket layer initialized
    [    7.380974] Bluetooth: SCO socket layer initialized
    [    7.731197] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
    [    7.780946] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [    7.903782] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [    7.953764] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [    7.970595] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    7.996005] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    8.124455] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [    8.164414] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    8.194181] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    8.218597] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [    8.228043] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
    [    8.235072] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 1
    [    8.243215] xhci-hcd xhci-hcd.10.auto: USB3 root hub has no ports
    [    8.249590] xhci-hcd xhci-hcd.10.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
    [    8.259369] xhci-hcd xhci-hcd.10.auto: irq 538, io mem 0x31100000
    [    8.264505] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [    8.266655] hub 1-0:1.0: USB hub found
    [    8.279866] hub 1-0:1.0: 1 port detected
    [    8.317616] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    [    8.318013] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [    8.405707] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [    8.521958] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [    8.876643] audit: type=1334 audit(1651167932.952:6): prog-id=9 op=LOAD
    [    8.883526] audit: type=1334 audit(1651167932.960:7): prog-id=10 op=LOAD
    [    9.097066] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [    9.132853] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
    [    9.278534] audit: type=1006 audit(1651167933.356:8): pid=657 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [    9.291350] audit: type=1300 audit(1651167933.356:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd0e16288 a2=4 a3=ffffb759b020 items=0 ppid=1 pid=657 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [    9.318769] audit: type=1327 audit(1651167933.356:8): proctitle="(systemd)"
    [    9.928858] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    9.974401] audit: type=1006 audit(1651167934.052:9): pid=634 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
    [    9.986960] audit: type=1300 audit(1651167934.052:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd0e16288 a2=4 a3=ffffb759b020 items=0 ppid=1 pid=634 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
    [   10.013266] audit: type=1327 audit(1651167934.052:9): proctitle="(weston)"
    I replace the uEvent.txt which copy from sdk806 ,It also dmesg|grep imx219 has none
    Net:   eth0: ethernet@8000000port@1
    Hit any key to stop autoboot:  0
    => printenv name_overlays
    ## Error: "name_overlays" not defined
    => setenv  name_overlays k3-am62a7-sk-csi2-imx219.dtbo
    I setenv on u-boot,and send boot cmd ,It still has nothing about imx219
    => savee
    Unknown command 'savee' - try 'help'
    => boot
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    487 bytes read in 21 ms (22.5 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    Running uenvcmd ...
    1 bytes read in 22 ms (0 Bytes/s)
    Already setup.
    ## Error: "main_cpsw0_qsgmii_phyinit" not defined
    20302336 bytes read in 828 ms (23.4 MiB/s)
    57364 bytes read in 26 ms (2.1 MiB/s)
    Working FDT set to 88000000
    Failed to load '/boot/dtb/ti/k3-am62a7-sk-csi2-imx219.dtbo'
       Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
    Working FDT set to 8feee000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  • Hi Daiwei,
    The dtbo file name was changed in 9.1:
    root@am62axx-evm:~# ls /boot/dtb/ti/k3-am62x-sk-csi2-imx219.dtbo
    You should use "setenv  name_overlays k3-am62x-sk-csi2-imx219.dtbo".
    Jianzhong
  • I tried it, but it still didn't work. This imx219 doesn't have a probe for printing. Can you use an EVM board to try my corresponding software version
  • Hello Daiwei,
    I have validated IMX219 with SDK 9.1. If you just add the following in /run/media/BOOT-mmcblk1p1/uEnv.txt, it should work, and you don't need to setenv from u-boot:
    name_overlays=k3-am62x-sk-csi2-imx219.dtbo
    Can you look at the dmesg and see if the dtbo is properly loaded? If you don't mind, can you share the dmesg here?
    Thank you.
    Jianzhong
  • yes,It can open camera
    cd edgeai-tiovx-modules/
    ls
    vi CMakeLists.txt
    option(INSTALL_SRC "Install src under /opt" OFF)
    option(ENABLE_DCC_TOOL "Enable DCC Tuning Tool Support" ON)
    mkdir build
    cd build/
    cmake ../
    make -j
    make install
    history
    sync
    reboot
    check network
    open dcc tools
    fail
  • Hi Daiwei,
    Were you running a live streaming when you tried to do live tuning? If not, please do that. If yes, can you share the log on the EVM while streaming?
    Thank you.
    Jianzhong
  • systemctl  disable weston
    systemctl  disable edgeai-init
    systemctl  stop edgeai-init
    v4l2-ctl --list-devices
    media-ctl -V '"imx219 4-0010":0 [fmt:SRGGB10_1X10/1920x1080 field:none]'
    gst-launch-1.0 -v v4l2src device=/dev/video3 io-mode=dmabuf-import ! \
      video/x-bayer, width=1920, height=1080, framerate=30/1, format=rggb10 ! \
      tiovxisp sink_0::device=/dev/v4l-subdev2 sensor-name="SENSOR_SONY_IMX219_RPI" \
      dcc-isp-file=/opt/imaging/imx219/linear/dcc_viss_10b.bin sink_0::dcc-2a-file=/opt/imaging/imx219/linear/dcc_2a_10b.bin format-msb=9 ! \
      video/x-raw, format=NV12, width=1920, height=1080, framerate=30/1 ! kmssink driver-name=tidss
    I try it,It can capture from the dcc tools,and why sdk806 don't capture ,
    beause /opt/edgeai-tiovx-modules ?
  • Glad that it finally worked for you.
    Yes, tiovx-modules didn't build when enabling live tuning on SDK 8.6.
    Jianzhong
  • ok,thank you for your support
