TDA2PXEVM: early boot ,but it stop somewhere
Part Number: TDA2PXEVM
I'm terence who is now building early boot with vision SDK 03 05 in TDA2PXEVM board.When I patched the directory of "linux-kernel-addon/ earlyboot-kernel-patches/* " for  omap, just refer to VisionSDK_Linux_UserGuide.pdf, system is booting but stop in "Started D-Bus System Message Bus." every time. Could you help me have a look.The following is the boot log.
Thank you very much
Terence Xia from China
mount: unknown filesystem type 'dev'
Welcome to Arago 2016.12!
[ SKIP ] Ordering cycle found, skipping alignment.service
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on Journal Socket.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Created slice User and Session Slice.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Reached target Swap.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on Syslog Socket.
[ OK ] Created slice System Slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
Mounting Temporary Directory...
Starting Setup Virtual Console...
Mounting Debug File System...
Starting Create list of required st... nodes for the current kernel...
[ OK ] Reached target Slices.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
Mounting POSIX Message Queue File System...
Starting Load Kernel Modules...
Starting Remount Root and Kernel File Systems...
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Paths.
Starting Journal Service...
[ OK ] Reached target Remote File Systems.
[ OK ] Created slice system-getty.slice.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Debug File System.
[ OK ] Mounted Temporary Directory.
[ OK ] Started Journal Service.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Remount Root and Kernel File Systems.
Starting Load/Save Random Seed...
Starting udev Coldplug all Devices...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Flush Journal to Persistent Storage.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Found device /dev/ttyS0.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Found device /dev/ttyS9.
[ OK ] Started Network Time Synchronization.
Starting Synchronize System and HW clocks...
[ OK ] Reached target System Time Synchronized.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting rc.pvr.service...
[ OK ] Started Kernel Logging Service.
Starting Permit User Sessions...
Starting Login Service...
[ OK ] Started D-Bus System Message Bus.
  • Hi Terence,
    From your logs, I notice that all kernel modules are failing to load. This is because the kernel image (uImage) and modules are miss-matched.
    Please follow all instructions in section 3.4 of the Linux-User-guide . This includes rebuild of Linux and running early-boot-update.sh scripts.
    Shravan
  • Hi Shravan,
    I had rebuilt with following section 3.4 of the Linux-User-guide, but the issue still remains. After rebuilt, system continued to run , stopped at "[ **] (2 of 3) A start job is running for dev-ttyO0.device (41s / 1min 30s)". If I turn off the power ,and then turn up it to reset system of the TDA2PXEVM board , boot log is the same as before,it will stop at "Started D-Bus System Message Bus". The following is boot log. Could you help to have a look?
    Thank you very much
    ===================================boot log =========================================
    ÿ¸mount: mount point /sys does not exist
    mount: mount point /dev does not exist
    mount: mount point /proc does not exist
    mount: mount point /var/volatile does not exist
    mkdir: can't create directory '/var/volatile/tmp': No such file or directory
    System time before build time, advancing clock.
    [ SKIP ] Ordering cycle found, skipping D-Bus System Message Bus Socket
    Starting Rebuild Hardware Database...
    Starting Rebuild Dynamic Linker Cache...
    Mounting /var/volatile...
    [ OK ] Mounted /var/volatile.
    Starting Rebuild Journal Catalog...
    Starting Opkg first boot configure...
    [ OK ] Started Rebuild Journal Catalog.
    [ OK ] Started Rebuild Hardware Database.
    [ OK ] Started Opkg first boot configure.
    [ OK ] Started Rebuild Dynamic Linker Cache.
    Starting Update is Completed...
    [ OK ] Started Update is Completed.
    Starting Network Service...
    [ OK ] Started System Logging Service.
    [ OK ] Started Permit User Sessions.
    [ OK ] Started Getty on tty1.
    [ OK ] Started Network Service.
    [ OK ] Reached target Network.
    Starting Network Name Resolution...
    [ OK ] Started Network Name Resolution.
    [ OK ] Started rc.pvr.service.
    Starting weston.service...
    [ OK ] Started weston.service.
    Starting tiipclad-daemon.service...
    Starting telnetd.service...
    [ OK ] Started telnetd.service.
    [ OK ] Started tiipclad-daemon.service.
    Starting ecarxinit.service...
    [ OK ] Started ecarxinit.service.
    [ **] (2 of 3) A start job is running for dev-ttyO0.device (41s / 1min 30s) @
    煀DA 悀
    V ÿmount: unknown filesystem type 'dev'
  • Hi Terence,
    The error is because the kernel isn't able to load the kernel modules. The below line from your logs indicates this.
    This is because the contents of the /lib/modules aren't updated. I would recommend re-flashing the file-system and running the steps.
    1. Apply the early-boot kernel patches
    2. In vision-SDK run the below commands:
       a) make clean
       b) make dep
       c) make linux
       d) make linux_install
       e) make vision_sdk
    3. After this you can will find the updated file-system in binaries/apps/tda2px_evm_linux_all/hlos/ (tar.gz file) folder. Untar this to get the file-system
    4. Now run the early-boot scripts passing as arguments the media containing the file-system.
    Shravan
  • Hi Shravan,
    Thank you ,I will try to do your suggestion today. But I have a question that If we do not enable this function of early boot,it still have this log. That is to say, normal boot is still have below line in my log. Even if there is have the log, system works normal.
    =======================log===============================
    My rebuilt steps in below,
    1.Checkout vision SDK code
    2.Apply the early-boot kernel patches
    3.Refer the VisionSDK_Linux_UserGuide.pdf to build
    3.1 make linux
    3.2 make linux_install
    3.3. make -s -j depend
    3.4 make -s -j
    4.Preparing SD card & Boot
    5.Run the early-boot scripts
    Thank you very much
    Terence Xia
  • Hi Terence,
    Can you try to reflash your file-system or try this on a new SD card. This looks like a file-system corruption.
    Shravan
  • Hi Shravan,
    We try it on a new SD card. The system stopped at "[ **] (1 of 3) A start job is running for dev-ttyO0.device (23s / 1min 30s)   [ TIME ] Timed out waiting for device dev-ttyS0.device. ", and then turned off/on power to reset , the system run and stopped at "[ OK ] Started D-Bus System Message Bus", just like before. The following is the log.
    Thank you very much
    Terence Xia
    ===========================boot log====================================
    [ OK ] Started Login Service.
    [DEPEND] Dependency failed for Serial Getty on ttyS0.
    [ TIME ] Timed out waiting for device dev-ttyO0.device.
    [DEPEND] Dependency failed for Serial Getty on ttyO0.
    [ TIME ] Timed out waiting for device dev-ttyS9.device.
    [DEPEND] Dependency failed for Serial Getty on ttyS9.
    [ OK ] Reached target Login Prompts.
    [ OK ] Reached target Multi-User System.
    Starting Update UTMP about System Runlevel Changes...
    [ OK ] Started Update UTMP about System Runlevel Changes.
  • Hi Shravan,
    It may be a difference in memory allocation that causes the issue, but I’m not sure. So, could you help me have a look? The below line is file of dra76-evm-infoadas.h
    Terence Xia
    =================================dra76-evm-infoadas.h==================================
    #include "dra76-evm.dts"
    #define DISABLE_PRCM(label) &label { ti,no-idle; ti,no-reset-on-init; }
    #define DISABLE_COMPLETE(label) &label { status = "disabled"; ti,no-idle; ti,no-reset-on-init; }
    #define LATE_ATTACH(label) &label { ti,late-attach; ti,no-idle; ti,no-reset-on-init; }
    chosen {
    bootargs = "console=ttyO9,115200n8 elevator=noop root=/dev/mmcblk0p2 rw rootwait earlyprintk=ttyO9,115200n8 fixrtc omapdrm.num_crtc=2 consoleblank=0 cma=16M rootfstype=ext4 snd.slots_reserved=1,1 loglevel=0 clk_ignore_unused init=/home/root/init-demo.sh";
    /* modules used by BIOS, disable from Linux */
    DISABLE_COMPLETE(vip1);
    DISABLE_COMPLETE(vip2);
    DISABLE_COMPLETE(cal);
    DISABLE_COMPLETE(i2c5);
    DISABLE_COMPLETE(wdt2);
    DISABLE_COMPLETE(vpe);
    DISABLE_COMPLETE(ocmcram1);
    DISABLE_COMPLETE(hdmi);
    DISABLE_COMPLETE(hdmi0);
    DISABLE_COMPLETE(dss);
    DISABLE_COMPLETE(dispc);
    DISABLE_COMPLETE(m_can0);
    DISABLE_COMPLETE(uart5);
    /* modules shared between BIOS and Linux, Do not reset or cutoff clks */
    DISABLE_PRCM(gpio1);
    DISABLE_PRCM(gpio2);
    DISABLE_PRCM(gpio3);
    DISABLE_PRCM(gpio4);
    DISABLE_PRCM(gpio5);
    DISABLE_PRCM(gpio6);
    /* Remote cores loaded by bootloader */
    LATE_ATTACH(ipu1);
    LATE_ATTACH(mmu_ipu1);
    LATE_ATTACH(ipu2);
    LATE_ATTACH(mmu_ipu2);
    LATE_ATTACH(dsp1);
    LATE_ATTACH(mmu0_dsp1);
    LATE_ATTACH(mmu1_dsp1);
    LATE_ATTACH(dsp2);
    LATE_ATTACH(mmu0_dsp2);
    LATE_ATTACH(mmu1_dsp2);
    /* timers used by the remote cores */
    LATE_ATTACH(timer3);
    LATE_ATTACH(timer4);
    LATE_ATTACH(timer5);
    LATE_ATTACH(timer6);
    LATE_ATTACH(timer7);
    LATE_ATTACH(timer9);
    LATE_ATTACH(timer11);
    LATE_ATTACH(timer13);
    LATE_ATTACH(timer14);
    LATE_ATTACH(mailbox5);
    LATE_ATTACH(mailbox6);
    LATE_ATTACH(mailbox7);
    /* Linux uses first 32 channels, BIOS uses last 32 */
    &edma {
    dma-requests = <32>;
    /* Update the CMA regions for Vision SDK binaries */
    &ipu2_cma_pool {
    reg = <0x0 0x96000000 0x0 0x2000000>;
    &dsp1_cma_pool {
    reg = <0x0 0x98000000 0x0 0x1000000>;
    &ipu1_cma_pool {
    reg = <0x0 0x9a000000 0x0 0x1000000>;
    &dsp2_cma_pool {
    reg = <0x0 0x99000000 0x0 0x1000000>;
    /* Additional memory regions required for Vision SDK
    * Keep this in sync with VSDK apps/build/tda2px/mem_segment_definition_linux.xs
    &reserved_mem {
    cmem_ocmc: cmem@40300000 {
    compatible = "shared-dma-pool";
    reg = <0x0 0x40300000 0x0 0x300000>;
    sram = <&ocmcram1>;
    no-map;
    status = "okay";
    cmem_pool: cmem@9e000000 {
    reg = <0x0 0x9e000000 0x0 0x1000000>;
    no-map;
    status = "okay";
    vsdk_sr1_mem: vsdk_sr1_mem@86000000 {
    reg = <0x0 0x86000000 0x0 0x9E00000>;
    status = "okay";
    vsdk_sr0_mem: vsdk_sr0_mem@9fb00000 {
    reg = <0x0 0x9fb00000 0x0 0x500000>;
    status = "okay";
    vsdk_eve_mem: vsdk_eve_mem@84000000 {
    reg = <0x0 0x84000000 0x0 0x1000000>;
    status = "okay";
    /* Memory reserved for IOMMU table carveout in u-boot */
    latea_pagetbl: late_pgtbl@bfc00000 {
    reg = <0x0 0xbfc00000 0x0 0x100000>;
    no-map;
    status = "okay";
    &ipu2 {
    /delete-property/ watchdog-timers;
    timers= <&timer9>;
    &ipu1 {
    &dsp1 {
    &dsp2 {
  • Hi Terence,
    You're DTB file looks fine. Are you sure you're pointing to the correct FS? The argument ' root=/dev/mmcblk0p2' in the chosen node in the DT refers to EMMC. Are you using the EMMC for boot? If you're using SD you may want to change this to 'root=/dev/mmcblk1p2'.
    Shravan
  • Hi Shravan,
    1. For early boot,if we changed the argument ' root=/dev/mmcblk0p2' to 'root=/dev/mmcblk1p2', there is no log from console. About this, I do not understand that we preparing SD card & Boot refer to VisionSDK_Linux_UserGuide.pdf, it belongs to boot from SD card mode. For normal boot,there is a uenv.txt which indicate the boot mode we used.
    =================================uenv.txt==================================================
    fdtfile=dra76-evm-infoadas.dtb
    args_mmc=part uuid mmc 0:2 uuid; setenv bootargs "console=ttyS9,115200n8 vram=16M root=PARTUUID=${uuid} rw rootwait ip=none mem=512M"
    2.For early boot,we had succeed once time, but after turn off /on to reset , there had occurred the above issues what communicated with you.This is a strange question.Looking forward to your help. The following is log of early boot successfully.
    =================================successed early boot log======================================
    [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [FAILED] Failed to start Rebuild Dynamic Linker Cache.
    See 'systemctl status ldconfig.service' for details.
    [ OK ] Started Serial Getty on ttyS0.
    [ OK ] Started Serial Getty on ttyS9.
    _____ _____ _ _
    | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
    | | _| .'| . | . | | __| _| . | | | -_| _| _|
    |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
    |___| |___|
    Arago Project http://arago-project.org dra7xx-evm ttyS9
    Arago 2016.12 dra7xx-evm ttyS9
    dra7xx-evm login:
  • Hi Shravan,
    For early boot,we tried nine times, and boot normal twice,and it must to reflash SD card again, every time. No matter boot normal or fail, we just turn off /on power to reset,it alway stop at "Started D-Bus System Message Bus".
    Terence Xia
  • Hi Shravan,
    The problem had been resolved.The reason is that the default address of latea_pagetbl from the TI's patch is out of our memory.
    no-map;
    status = "okay";
