Other Parts Discussed in Thread: PGA460, TIDA-00151, USB2ANY
Can you help let know if the PGA450-Q1 IC is pre programmed ? Is there any possibility that the default values coming in the OTP and DEV ram can be used for an application ? If so please let know the reference where the default values of OTP and Dev ram are present without any programming.
Also can you let us know if the GUI for programming with work with any USB to SPI based programming debugger? If not can you suggest us some compatible ones?
Thanks and Regards,
Rohith TR
