| Audio Switches | Features & Parameters | Multiplexer Selection Guide | Resolving Common Design Challenges | Simulation Modeling |
| Training & Resources | Quality & Packaging | Switches & Multiplexers E2E Home Page |
1. [FAQ] How to Handle Replacing a Pin-to-Pin Multiplexer that has a Logic Supply Pin
2. [FAQ] Can I use Dual Supply Analog Switches/Multiplexers with a Single or Asymmetric Supply?
3. [FAQ] How to Calculate the Max Junction Temperature of an Analog Switch/Multiplexer.
4. [FAQ] Can TI Analog Switches/Multiplexers be Ground Shifted?
5. [FAQ] Debugging and Fixing Overshoot in Switching Events
6. [FAQ] What is the Difference between an Analog Signal Chain Multiplexer and a Relay?
7. [FAQ] How do I Approximate Propagation Delay and Channel to Channel Skew in an Analog Switch/Multiplexer?
8. [FAQ] What to do with Unused Pins & Exposed Thermal Pads?
____________________________________________________________________________________________________________________________
