[FAQ] Multiplexer Selection Guides - Frequently Asked Questions
Audio Switches Features & Parameters Multiplexer Selection Guide Resolving Common Design Challenges Simulation Modeling
Training & Resources
Quality & Packaging Switches & Multiplexers E2E Home Page  Arrow right
By Analog Voltage
1. [FAQ] Multiplexers and Switches Selection Guide | Low Voltage VSIGNAL =< 24V
2. [FAQ] Multiplexers and Switches Selection Guide | Mid Voltage Mux 25V =< VSIGNAL =< 99V
By Protocol -
1. [FAQ] How do I Select the Right Analog Switch/Multiplexer Bandwidth Based on the Data Rate of my Protocol?
2. [FAQ] What Analog Switch / Multiplexer Should I use for I3C Applications?
3. [FAQ] What Analog Switch / Multiplexer Should I use for I2C Applications?
4. [FAQ] What Analog Switch / Multiplexer Should I use for SPI Applications (3/4 Wire SPI, QSPI, or OSPI) ?
5. [FAQ] What Analog Switch / Multiplexer Should I use for UART Applications?
6. [FAQ] What Analog Switch / Multiplexer should I use for GPIO expansion applications?
7. [FAQ] What Analog Switch / Multiplexer Should I Use for JTAG applications?
8. [FAQ] What Analog Switch / Multiplexer Should I Use for I2S Applications?
9. [FAQ] What Analog Switch / Multiplexer Should I Use for LVDS Applications?
10. [FAQ] What Analog Switch / Mulitplexer Should I use for MIPI applications?
11. [FAQ]: What Multiplexers or Switches can I use for RS-232, RS-422, and RS-485 Applications?
1
2. [FAQ]: Auto Protocol Selection Guide
General
1. [FAQ] What are TI’s Signal Switch/Multiplexer Naming Conventions?
2. [FAQ] Automotive Rated Signal Switches and Multiplexers
3. [FAQ] Industry Standard 3257 Switch Options
4. [FAQ| What are the differences between PCA and TCA I2C switches?
5. [FAQ] What Multiplexers can I use for Hot-Swapping and Hot-Insertion Applications?
____________________________________________________________________________________________________________________________
