Other Parts Discussed in Thread: UNIFLASH, Z-STACK
Hi, I am following this Project Zero tutorial https://dev.ti.com/tirex/explore/node?node=AD86J5EtUKXcvz0SahPrBA__pTTHBmu__LATEST
Hardware that I am using:
- BeagleBone Green Gateway as host
- LAUNCHXL-CC1352R1 as the Network ZNP / Zigbee Coordinator
When I plug in the Launchpad I am able to confirm that it is connected (in /dev/ttyACM*. However, after running
cd ~/source/Projects/node sudo ./start_local.sh
I get the error message:
I can also confirm that the setup.sh and buildall script run successfully since an out folder is generated instead of ERROR___OUT. This error keeps running in a loop until I kill it. Any thoughts? I was unable to find any pointers on the 1 or 2 related threads.
