[FAQ] DP/HDMI/SDI/DPHY Products FAQ Master List
Mastermind 26791 points
Part Number: TDP2004
This Master FAQ lists serves as a point of reference to find all FAQs made by TI's signal conditioning Team.
DPHY:
1. [FAQ] SN75DPHY440SS: Is it okay to swap the polarity and lane order? - Interface forum - Interface - TI E2E support forums
2. [FAQ] SN65DPHY440SS: What is the design constraint for DPHY440 lane 0 when using in a MIPI CSI design? - Interface forum - Interface - TI E2E support forums
HDMI/DP:
1. [FAQ] TDP1204: When to AC or DC couple the HDMI 2.1 output? - Interface forum - Interface - TI E2E support forums
2. [FAQ] Linear vs. Limited Mode in Redrivers - Interface forum - Interface - TI E2E support forums
3. [FAQ] How to enable snoop mode with HDMI re-driver/re-timer - Interface forum - Interface - TI E2E support forums
4. [FAQ] TMUXHS4212: When and how to AC coupling the passive MUX? - Interface forum - Interface - TI E2E support forums
5. [FAQ] DP++ & Dual Mode Implementation using a DP redriver - Interface forum - Interface - TI E2E support forums
6. [FAQ] Suggested Common Mode Chokes and ESD devices for Highspeed Video Devices (1Gbps+) - Interface forum - Interface - TI E2E support forums
7. [FAQ] Measuring the maximum drive distance of a signal conditioner across a cable - Interface forum - Interface - TI E2E support forums
8. [FAQ] TDP142: Linearity Range Description - Interface forum - Interface - TI E2E support forums
9. [FAQ] TDP2004: What is DisplayPort Pre-emphasis and how does a linear re-driver impacts it - Interface forum - Interface - TI E2E support forums
10. [FAQ] What data rates support which resolutions? - Interface forum - Interface - TI E2E support forums
11. [FAQ] How to enable snoop mode with HDMI re-driver/re-timer - Interface forum - Interface - TI E2E support forums
12. [FAQ] TDP1204: What is the difference between the TDP1204 and the TMDS1204 HDMI 2.1 redrivers? - Interface forum - Interface - TI E2E support forums
13.
SDI:
  1. [FAQ] LMH1297: Why should I pay attention to the return loss performance? - Interface forum - Interface - TI E2E support forums
  2. [FAQ] LMH1228: Pre-Emphasis, Rise Time/ Fall Time and VOD Overshoot - Interface - INTERNAL forum - Interface - INTERNAL - TI E2E support forums
  3. [FAQ] LMH1297: SDI and Ethernet CDRs eye diagram capture - Interface forum - Interface - TI E2E support forums
  4. [FAQ] LMH1229: Understanding Jitter Measurements - Interface forum - Interface - TI E2E support forums
  5. [FAQ] LMH1297: EOM - Eye Opening Monitor - How to Re-Construct Eye Diagram - Interface forum - Interface - TI E2E support forums
  6. (+) [FAQ] LMH1239: SDI Layout Suggestions - Interface forum - Interface - TI E2E support forums
