Part Number: TPS65986
I see that 0xFF return code should be considered an error in Write command. It appears that once 1 FLwd command fails, all subsequent FLwd commands will fail. Is this expected? What needs to be done to retry FLwd commands once 0xFF return code is encountered, and is there any way to get more details from the TPS65986 in terms of why FLwd failed and/or where it failed? (for writes with several Bytes of data, since FLwd can be 1 to 64 Bytes).
Thank you.
