Part Number: AM263P4
In the AM263Px datasheet rev C, the VPP voltage maximum is listed as 1.75V. Also the datasheet requires "The VPP power supply must be disabled when not programming OTP registers."
However the AM263 to AM263P Migration Overview (Rev. A). recommends supplying VPP directly with ANALDO (also named VDDA18_LDO) which outputs 1.8V.
The LP-AM263P4 board schematic supplies VPP with VDDA18_LDO in this way.
It would be easier to design our board VPP supply like LPAM263P4, however we want to be careful to follow the datasheet requirements if those are required.
Which raises two questions:
- Is it OK to supply VPP with 1.8V?
- Is it OK to supply VPP when not programming OTP registers?
