Part Number: DP83867IR
Other Parts Discussed in Thread: CDCLVC1103
Hi Team,
When my customer did compliance test of their DP83867IR board under 10Base-Te / 100Base-TX / 1000Base-T, the compliance test results became as follows,
I would appreciate any advice on their compliance test results.
Their compliance test results is:
DP83867IR Compliance Test Results 20200506.pdf
<10Base-Te>
- 4 fails at the following items,
1) TP_IDL Template, with TPM (last bit CD0) : Fail at Load2
2) TP_IDL Template, with TPM (last bit CD1) : Fail at Load2
3) TP_IDL Template, without TPM (last bit CD1) : Fail at Load1
4) Transmitter Return Loss
*In case of 1) and 2), because TP_IDL amplitude was lower, failed at Load2.
You did the compliance test with the DP83867 EVM, so could you share the compliance test results of the DP83867 EVM to compare with their results?
<100Base-TX>
- Passed all items.
<1000BASE-T>
- 1 fail at the following item,
1) Difference A,B Peak Output Voltage(w/ Disturbing Signal)
*The thread related to this issue can be seen in the E2E community, but it became the private communication, they cannot understand the solution.
Could you share the solution to solve this issue?
Thank you.
Koshi Ninomiya
