Other Parts Discussed in Thread: LP8764-Q1, TPS6593-Q1, TPS65224-Q1, TPS6594-Q1
TPS6594-Q1, TPS6593-Q1, LP8764-Q1, TPS65224-Q1 FAQ Home Page
This home page is for common questions in relation to the TPS6594-Q1, TPS6593-Q1, LP8764-Q1, and TPS65224-Q1 PMICs.
Frequently Asked Questions (FAQs)
Documentation:
- [FAQ] TPS6594-Q1: User Guide Locations
- [FAQ] TPS6594-Q1 and TPS6593-Q1 Thermal model
- [FAQ] TPS6594-Q1: TPS6594-Q1 differences of orderables?
EVM:
General Usage:
- [FAQ] TPS6594-Q1: How do I enable EN_DRV?
- [FAQ] TPS6594-Q1: Residual Voltage Check
- [FAQ] TPS6594-Q1: TPS6594-Q1, LP8764-Q1: Device Start up: On Requests sources and destinations
- [FAQ] TPS6594-Q1: TPS6594-Q1, LP8764, LP876x: Can LDOVINT and LDOVRTC be used to power small Loads?
I2C:
IO (Inputs/Outputs):
- [FAQ] TPS6594-Q1: TPS6594-Q1 and LP8764-Q1: Can unused buck feedback pins be used to monitor external voltages?
- [FAQ] TPS6594-Q1: How to connect unused IO.
Monitoring:
NVM (Non-Volatile Memory):
- [FAQ] TPS6594-Q1: How to reprogram non-volatile memory on TPS6594-Q1 and LP876x-Q1
- [FAQ] TPS6594-Q1: TPS6594, LP8764: How can I confirm that the correct NVM is programmed?
- [FAQ] TPS6594-Q1: TPS6594, LP8764: Are customers able to write their own programming for PMIC NVM?
- [FAQ] TPS6594-Q1: TPS6594-Q1, LP8764-Q1: Can TI create a custom program according to customer use?
RTC (Real-Time Clock):
- [FAQ] TPS6594-Q1: [FAQ] TPS6594, LP8764: Is the RTC function required for a functioning PMIC Device?
Schematic and Layout:
- [FAQ] TPS6594-Q1: BOOSTXL-TPS6594 Schematic
- [FAQ] TPS6594-Q1: Schematics and PCB Checklist for TI Review Feedback
- [FAQ] TPS65224: Schematic and layout review checklist
Standards and Compliance:
Troubleshooting:
- [FAQ] TPS6594-Q1: Infinite RECOV_CNT
- [FAQ] TPS6594-Q1: Gui Composer Firmware update fails.
- [FAQ] TPS6594-Q1: LP8764-Q1: Debugging PMIC Behavior with Interrupt Interpretation.
- [FAQ] TPS6594-Q1: Why does my board work with ES1.0 units but not with ES2.0 units?
Watchdog (WDT):
