Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
[FAQ] [H] High-Speed Amplifiers Stability
Frequently Asked Questions: Amplifiers >> High Speed Amplifiers >> Stability
Circuit Design Considerations Transimpedance Amplifier Circuits Fully Differential Amplifier Circuits ADC Driver Circuits Other Op Amp Circuits
Stability Input/Output Limitations PCB Layout Guidelines Simulation & Modeling Power, Thermal, Quality, & Manufacturing
Stability
Related Content:
Decompensated Amplifier Stabilization Circuit
Stabilizing Differential Amplifiers as Attenuators Design Guide
Maximizing System Total Harmonic Distortion Using High Speed Amplifiers
Has distortion got your amplifier down? Get more bandwidth!
Top E2E FAQs and Posts:
How to convert phase noise unit "dBc/Hz" to "rad/√Hz"?
OPA847: Voltage Noise Peaking in Transimpedance Amplifier (TIA) - why does the addition of a feedback capacitor cause voltage noise peaking?
OPA858: Photodiode Amplifier for Short (1-2ns) Laser Pulse
TINA/Spice/OPA855: OPA855 Transimpedance Amplifier self-oscillation
LMP7718: Stability analysis of TIA with DC servo
TINA/Spice/LMH6505: Simulation configuration to determine open loop gain & phase response (stability)
OPA656: Small Signal Bandwidth and its relationship to the Gain-Bandwidth Product
THS3217: How to minimize overshoot
TINA/Spice/OPA657: Very Basic Query regarding Phase Margin/Stability
OPA2863: AC Pspice Simulation for Stability + Monte Carlo
OPA657: Simulation error
Is your op amp filter ringing? Look at Q!
