[FAQ] [H] High-Speed Amplifiers ADC Driver Amplifier Circuits
Frequently Asked Questions: Amplifiers >> High Speed Amplifiers >> ADC Driver Circuits
Circuit Design Considerations Transimpedance Amplifier Circuits Fully Differential Amplifier Circuits ADC Driver Circuits Other Op Amp Circuits
Stability Input/Output Limitations PCB Layout Guidelines Simulation & Modeling Power, Thermal, Quality, & Manufacturing
Related Content:
ADC Input Protection
Analog Front-End Design With Texas Instruments’ Tooling Landscape
TIGAR (Texas Instruments Graphical Evaluation of ADC Response Tool)
Attenuator Amplifier Design to Maximize the Input Voltage of Differential ADCs
16-bit settling for your high-throughput data acquisition system
2 steps to achieve 16-bit settling for your high-throughput data-acquisition system
Antialiasing filter circuit design for single-ended ADC input using fixed cutoff
Using single-supply fully diff. amps with neg. input voltages to drive ADCs
Circuit for differential output from a single-ended precision DAC
High Dynamic-Range Headphone Driver for DACs Design Guide
ADC32RF45: Amplifier to ADC Interface
Setting a Constant Common-Mode Voltage for Fully-Differential SAR ADC Inputs
High-input impedance, true differential, AFE attenuator circuit for SAR ADCs
Inverting circuit for high-to-low voltage level translation to drive ADC
Driving a low-voltage single-ended SAR ADC circuit with high-voltage input
Reducing amplifier power consumption for SAR ADC drivers
Top E2E FAQs and Posts:
[FAQ]: FDA Device Selection Guide
THS4541: THS4541 as ADC driver: induces DC offset on the input signal
THS3217: High Linearity DAC driver
THS4551: How to achieve the highest signal to noise ratio for a high gain (G = 50) 16 bit ADC application
OPA354: Where to add gain for a SAR driver?
LMH6518: LMH6518 interfacing to THS4541
I-V stage calculations
THS4503: THS4503 application question
