Browse By Tags
  • XTR115: Design schematic for two pin sensor
    Part Number: XTR115
    Other Parts Discussed in Thread: XTR117, XTR116
    I want to design a 2-wire transmission line by XTR115. But my sensor is not a bridge sensor. I need a schematic to show me how can I connect the sensor with v- and v+ to the IC…
  • OPA2835: Request for suggestions for using Attenuator for Voltage signal
  • XTR117: No 4-20mA output Current
    Part Number: XTR117
    Other Parts Discussed in Thread: INA321, LM317, INA823, XTR115, XTR116, XTR111
    0081.pdf
    Dear Team
    I have designed the 4-20mA transmitter using XTR117(transmitter) and INA321(amplifier)
    I am facing issues in this particular design…
  • XTR115: XTR115 measuring a potentiometer input as the sensor type.
    Part Number: XTR115
    Other Parts Discussed in Thread: XTR116, LOG114, XTR111
    Hi All,
    A few years ago I investigated connecting a potentiometer (three wires) directly to the XTR115 to give a linear input relative to position relative to current.
    I found…
  • XTR116: Producing a 4-20mA current loop alongside an MCP4921 DAC
    Part Number: XTR116
    Other Parts Discussed in Thread: MIKROELEKTRONIKA
    Hi
    I recently purchased a MikroElektronika 4-20mA T Click MCU Add On Board MIKROE-1296 for an application that I need for a project at work, which has a 24V source connected to the…
  • XTR117: Long distance transmission for analog signal
    Part Number: XTR117
    Other Parts Discussed in Thread: XTR115, XTR116
    Application: Analog 0V-5V to 4mA-20mA
    I am looking for current loop IC (2 wire) which can transmit signal across 5m or more cable distance .
    1. Can you provide suitable IC options…
  • XTR115:XTR115第8引脚输出驱动电流
    Part Number: XTR115
    请XTR115第8引脚输出驱动电流是多大?
  • XTR112: Kindly provide the temperature information regarding XTR112UA
    Part Number: XTR112
    Other Parts Discussed in Thread: XTR300, XTR305, , XTR117, XTR111, XTR116, INA333, INA333-HT
    Hi Team,
    While checking the datasheet it is given as operating and storage temperature as -55 degree Celsius to 125 degree Celsius
    Is it the…
  • XTR116: PWM control for 4-20mA current loop with Microcontroller
    Part Number: XTR116
    Other Parts Discussed in Thread: ISO7310-Q1
    We are trying to develop a 4 – 20mA current transmitter. The control is done by a PWM signal issued by a microcontroller.
    I can't quite understand the values of R3 (Rin) and…
  • PGA308: A3SAT_LO fault resolution
    Part Number: PGA308
    Other Parts Discussed in Thread: , XTR116
    Hello TI team,
    My application is very similar to Figure 6-3 of your publication “SBOU069B–June 2009–Revised January 2012” (i.e. TI PGA308 User Guide).
    The only exception…
  • XTR116: PWM to 4-20mA
    Part Number: XTR116
    Other Parts Discussed in Thread: ISO7321FC
    Hi Team,
    According to our customer, he built this system according to the datasheet and following the steps in Collin Wells' technical blog in the link below.
    https://e2e.ti.com/blogs_…
  • XTR116: XTR116
    Part Number: XTR116
    Other Parts Discussed in Thread: TLV9052, OPA391, OPA187, TLV2186, OPA2187, OPA2186, OPA192, XTR105, OPA186
    Are there any recommended circuit modifications we could make when using the XTR116U part that would allow the chip to go into…
  • OPA2333: SBOA379 Reference Design Schematic
    Part Number: OPA2333
    Other Parts Discussed in Thread: XTR117, XTR115, XTR116, XTR111, XTR300
    Hi Team,
    Our customer is interested in our SBOA379 reference design in below link, but we can not find the related schematic, can you help to share with us for…
  • XTR115: XTR115 output current drift during IEC61000-4-6: Conducted Immunity test
    Part Number: XTR115
    Other Parts Discussed in Thread: XTR117, XTR116, DAC8551, XTR111
    We are facing issues in the XTR115 chip (4-20mA Transmitter) during the EMI/EMC Conducted Sustainability (CS) Test of our product.
    The issue is that 4-20mA current output…
  • XTR117: XTR117
    Part Number: XTR117
    Other Parts Discussed in Thread: XTR111, XTR115, XTR116, XTR305, XTR300, TIPD155, DAC128S085, XTR110, TIPD102, OPA2333, OPA2197, OPA2192, OPA197, TLV2172, OPA192
    Can we use XTR117 for 0-20mA Transmitter
  • XTR117: XTR117 design check request
    Part Number: XTR117
    Other Parts Discussed in Thread: XTR116, , OPA2188, XTR111, TIDA-01536
    I'm building an isolated bipolar +-10V or current 4mA..20mA output module.
    The voltage generator use an SPI isolator and 16 bit DAC.
    The power lines are…
  • XTR117: MSP430 and XTR117
    Part Number: XTR117
    Other Parts Discussed in Thread: XTR115, XTR116, XTR111
    We are working on one 2 wire transmitter application where we have to use XTR117 and MSP430 microcontrollers.
    Also, it should have a segmented LCD and ultra-low power EEPROM…
  • XTR116: XTR116
    Part Number: XTR116
    Other Parts Discussed in Thread: XTR106
    We have designed a 4-20mA product in the datasheet they have told non linearity error is 0.003% but we are getting 3% error please find attached schematics and help me out anyone find bug4-20mA…
  • XTR117: XTR117 in a 2/3-wire situation
    Part Number: XTR117
    is it possible to use the XTR117 in a 2/3 wire loop situation. The goal is to set for example an jumper to switch between 2 and 3 Wire.
    In the 2 wire situation the XTR117 is…
  • INA828: Differential output
    Part Number: INA828
    Other Parts Discussed in Thread: THP210, XTR116, ADS1258-EP, ADS1278-EP, ADS1298R, INA826EVM, OPA828, ADS1261, ADS131E08, TINA-TI, OPA191
    I have a loadcell which gives a differential output of 0-20mV with the INA828 connected to this…
  • High reliable part
    Other Parts Discussed in Thread: PGA305, PGA300, INA271-HT
    Hi Experts,
    Good day.
    We would like to ask your assistance in looking for high reliable parts for this current to conversation.
    Client need to measure the pressure using our op-amp with a pressure…
  • INA326: RTD to Voltage Reference Design document query (tidu969)
    Part Number: INA326
    Other Parts Discussed in Thread: INA327, TINA-TI
    Hello Guys,
    Good day.
    Our customer have a question about the tidu969.pdf document as shown below:
    "Looking at Figure 5 on PDF page 5, the values of R4 and R5 are equal to 10k.  This…
  • TIPD126: XTR115 outputs 40mA
    Part Number: TIPD126
    Other Parts Discussed in Thread: XTR117, , PGA309, XTR115, XTR111
    I followed the TIPD126 design with some modifications on my end, primarily switching out the xtr117 for the xtr115 for the extra reference current. I use a 500ohm…
  • support for two channel 4-20mA loop powered transmitter
    Other Parts Discussed in Thread: XTR116, XTR111
    hi,
    We trying to design two channel 4-20 mA loop powered transmitter for Temperature and Relative humidity. my issue is, how to use ground signal in loop powered design. i have attached block diagram image…
  • XTR116: Difference between XTR116U vs. XTR116UA
    Part Number: XTR116
    Hi Amps,
    What is the difference between XTR116U and XTR116UA?
    I did look at the datasheet and all of the electrical characteristics seems to be same, even the packaging info seems to be the same?
    Rgds,
    Kris
1 2 3 4 5 »
